I have found a 1970 corvette without engines in it I have the vin number can anyone give me some information on wher i can go to serch the vin number to find out what was in the car org. from the factory. Thanks for any help. All running gears and any options. the numbers are 194670S412373.
just a quick one.. i just baught an 1981 vette.. there r only 2 VIN numbers on the whole car it self... is that true? both located on the left hand side along the window and near the dash...??
I'll I could get was...
Division (1): Chevrolet
Car Line (9467): Corvette Convertible
Model Year (0): 1970
Plant (S): St. Louis, MO
Sequence Number: 412373
What would the tach. look like on 1970 corvette. If it was a big block car 454 how many RPM would it read and what would the red line be .Or is there any thing else I could look for to determine if it was a big block car. HELP
If the car has a rear sway bar then it was a big block.. The tach redline might give you also an indication on what engine was in the car, but there's no guarantee that it's still the original tach...
For a 1970 Corvette, the tachometers were 5300 redline for the ZQ3 engine, 5600 redline for the LS-5 engine, 6000 redline for the L-46 engine, and 6500 redline for the LT-1 engine.
