From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Originally Posted by Tired74
Can anyone provide part #'s for headers that fit a 350 HO Deluxe crate engine installed in a 74 coupe with 700R4 installed?
Dealers here are unsure and returns from my very remote location would be very expensive.
Hedman or Holley come to mind but other recommendations welcome.
Thank you
mine are either heddman or hooker....the only issue with the 700r4 is that the conventional premade exhaust systems will be right next to the 700r4 trans pan.....so you would be better off having a custom exhaust set made then buying one....remember the trans cross member is different so you don't hae to go through the previous crossmember holes so you have alot more options. i did not do this and ordered everything at once...so now in order to take down my trans pan i will need to take out the pass exhaust.
this is a 2.5" dual exhaust from corvette central
[IMG][/IMG]
[IMG][/IMG]
