Crager Wheel fu*** up!!!
First set I ordered from Jegs....3 of the 4...OUT OF ROUND!!!!. Jegs took all 4 back with no problems
!!!! DAMN! So the hell with it and went back to my stock wheels. I really liked the look of the Cragar wheels BUT the quality...... Summit is picking them up on Friday. Any recommends as far as American Racing Torque IIs?? By the way, I am taking her to Sport Car Specialty (Corvette body shop)in on Monday for them to fix the crack.....$300!!
Sorry to hear about the bad luck. Hope it all gets better soon.
Curious to see whether U.S. or out sourced.Sorry to hear about your misfortune. The only time I had Craeger's was back in the '60-70's and they seemed almost indestructible.
Any increase in forward spacing (ie go over the 4" as per the factory) you run the risk of hitting the fender. Also increasing wheel diameter and using a tire with a "bigger shoulder" will give clearance issues.
I replaced my 15 x 8, with 17 x 8 (with a 4" backspace) but becasue of the bigger footprint of a 255/50/17, it hit the lower lip of the fender.
If you where using a 3/4" spacer, you would have to use a 4-3/4" backspace wheel.
Nick
Nick
The Cragars will hit the brake calipers without a spacer and with a spacer, they hit the fenders. Not a good design for Corvettes.
http://cgi.ebay.com/ebaymotors/ws/eB...970046633&rd=1
I didn't order via eBay, I called him up. For $1/each he'll provide the lugs and he tossed the valve stems in no extra charge. Delivery was fast, price was right, I'd definitely buy from the guy again.
That being said... the 3.75" backspacing that AR specifies for the C3's kinda works... The wheels cleared my front calipers with no trouble, but they just BARELY scraped the rears. I wound up buying a set of Mr. Gasket 5/16" wheel spacers for the rears and it clears them just fine now.
