Recommendations for sandblaster?
Old Apr 30, 2005 | 02:34 PM
surfshark's Avatar
surfshark
Default Recommendations for sandblaster?
I hope this thread is okay for the Tech forum...I need to sandblast surface rust from a crossmember before painting it. What sandblasters work well for this type of task? I have a 5.5 HP compressor. How about the ones Harbor Freight sells? Thanks.
Old Apr 30, 2005 | 02:53 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
guess not..
I use a speed blaster
Old Apr 30, 2005 | 02:56 PM
surfshark's Avatar
surfshark
I guess my query about which wine goes best with manifold-baked chicken wouldn't go in Tech either.
Old Apr 30, 2005 | 03:03 PM
surfshark's Avatar
surfshark
Originally Posted by Corz
guess not..
Oh - thanks for your suggestion, Corz!
Old Apr 30, 2005 | 03:12 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I got one of those portable "bucket" type sandblasters from Sears. About $50. Just a container with the hose and gun. Works great. Lot depends on the type of sand you use.
Before I got mine I borrowed the same thing from my nephew. Took 2 hours to blast a few parts with the sand he had. Would have taken 5 minutes with the sand I put in mine.
Got a face shield and welders gloves to wear when using it.
Someday would like to get a cabinet unit, tho.
Mike
Old Apr 30, 2005 | 03:13 PM
Corz's Avatar
Corz
Old Apr 30, 2005 | 03:35 PM
mrtroutjedi's Avatar
mrtroutjedi
Probly a nice red wine
Old Apr 30, 2005 | 08:41 PM
surfshark's Avatar
surfshark
Mike
Thanks KapsSA - I wasn't aware of such a difference in the performance of the different types of sand. That will help me with my first purchase. I just got back from Harbor Freight a while ago, but they don't sell the blasting media anymore.
Hey Corz & mrtroutjedi - Now how do I keep the sand out of my chicken?
Old Apr 30, 2005 | 09:06 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
i bought a cheap one and sand shoots out the sides but duct tape fixed that. also you have to have one of those hings that takes out the water in the lines
Old Apr 30, 2005 | 09:49 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Has anyone used the sand blast attachment available for a pressure washer? Same principles, just uses a pressure washer to siphon the sand into the pressurized water. I would expect it to be cooler and not generate as much heat.
Has anyone tried this? Northern Tool sells one for about $50. jim
Old May 3, 2005 | 01:25 PM
Smooth72's Avatar
Smooth72
I have used the pressure washer sand blaster on a concrete picnic table it worked well. I bought a pressurized sand blaster from Harbor Freight, I went to sand blasting supply place and they recommenced crush glass. It cuts better, does not heat up as much, does not get clogged up in your blaster and they say it is much safer because it does not have silica in it. The only draw back is that it is a little more expensive.
Old May 3, 2005 | 01:34 PM
Frankenvette's Avatar
Frankenvette
I just got my rear suspension parts back from an industrial sand blasting business. They charged me $60.00 to blast all of my rear suspension parts, but oh man did it turn out great. The parts are so clean, I thought they had painted them a cast aluminum color for me. These parts literally look brand new. I can't remember the last time I got so excited over $60.00 spent on the vette. Hope to buy my own blasting cabinet one day, but for the price these guys charged me it may be cheaper in the long run for me to pay them to blast my parts.
Old May 3, 2005 | 03:14 PM
markdtn's Avatar
markdtn
I have 1 of those and it is OK with some improvements. The stock valve and nozzles are junk. Used to be able to buy a 1/4 turn rebuildable steel ball valve and good ceramic nozzles from SanBlast, but the owner retired. Apparantly you can get nozzles from Brut inc. They sell a true sandblasting type valve, which is a good thing I guess. If you use the stock valve from HF, DO NOT throttle the sand with it. It will cut itself apart-don't ask how I know. I blased my frame with it and many many parts since then. Probably should have bought the metal nozzle first time around, but I have stuck with ceramic. I go through a nozzle about every 500-800 lbs of sand (10-15 bags).
Oh, 1 more thing. I had a suction blaster and they are not nearly as effective as a pressure blaster for what that's worth.
Old May 3, 2005 | 05:02 PM
Steve COSD's Avatar
Steve COSD
There are a few things to know about blasters. The enclosed cabinet type is the best. TP Tools is the best place for this. They will work fine with a 5 horse compressor. An old shop vac will work along with this to clean the air in the cabinet to see what your doing. The vac wont last forever due to the dust. A cabinet also enables you to change the media to match what kind of job you are doing. Glass beads work very well with aluminum items such as intake manifolds,
alternator housings, nuts and bolts. Aluminum oxide works very well on rust. Pressure blasters or the open tank type are very messy and clog often in high humidity locations. If you have large items the cabinet won't work. If I were in you shoes I would take the part and have it powder coated. They will blast it before coating it. Also the coating is extremely durable. Try different places as the cost will very widely in some locations. If you are going to restore other parts of the car in the future get the cabinet. The quality of the part after blasting is amazing.
Good Luck
Steve
Old May 3, 2005 | 10:21 PM
markdtn's Avatar
markdtn
Originally Posted by Steve COSD
...TP Tools is the best place for this....
Pretty sure TP tools, TiP inc., and SanBlast were all sub-companies of Trumans incorporated. If you go to www.sanblast.com it sends you to www.brutmfg.com for parts and service.
Old May 4, 2005 | 10:19 AM
jimvette999's Avatar
jimvette999
Mike
I bought one similar to this from Lowe's and it works well. They sell the sand for it also. It was about $30, made in the USA. It's fine for home use I think. I blasted many suspension parts and doors (metal parts) hinges with no problems. With your compressor, you should have no problem running it. Mine has a ceramic tip on the nozzle which shows no signs of wear and I've used it approx. 15-20 hrs.
Jim
To Recommendations for sandblaster?
