Throttle Linkage adjustment
Old May 8, 2005 | 10:29 PM
79 Bullet's Avatar
79 Bullet
Default Throttle Linkage adjustment
I just installed a Demon and I need to adjust the throttle cable position to get full throttle. If you unclip the cable from the bracket, It doesn't look like you can move the cable backwards with relation to the clip that holds it on the metal bracket. Has anybody tried this?
Old May 9, 2005 | 09:10 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
....i used the bracketry from Bow Tie Overdrives because of the hook ups for the 700rv TV cable...you may want to use an inner return spring on that also
[IMG][/IMG]
