Distributor install tip
Old May 12, 2005 | 10:29 PM
isosceles's Avatar
isosceles
Default Distributor install tip
This is not my tip but I forgot the couple of members who suggested it in a previous thread. To those that did, THANK YOU!!!
For those of us who can get the distributor to drop in on the right tooth, but fight like crazy to get the oil pump shaft to line up, here's the tip I was referring to:
With the distributor installed and teeth engaged, but not quite fully seated because the oil pump shaft is not engaged, just BUMP THE STARTER.
I tried it tonight and it worked like a charm. Getting that stinking oil pump shaft to line up used to take me an hour easy, trial and error, removing and reinstalling the distributor, turning the oil pump shaft just a little at a time.
To the guys that suggested this method THANK YOU THANK YOU THANK YOU!!!!
It's like getting a phobia cured!
Old May 12, 2005 | 10:52 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Dumb question. How exactly do you 'bump' a starter?
thanks, Les
Old May 12, 2005 | 11:06 PM
isosceles's Avatar
isosceles
thanks, Les
Whoops: by quickly turning the key and letting go. not holding it and cranking like crazy.
Old May 13, 2005 | 12:49 AM
SkunkApe's Avatar
SkunkApe
Old May 13, 2005 | 01:13 AM
LFZ's Avatar
LFZ
Old School method...but always works.
Old May 13, 2005 | 06:32 AM
gerry72's Avatar
gerry72
You can also pull the distributor and turn the pump shaft into alignment with a screwdriver, then re-seat it.
Old May 13, 2005 | 09:03 AM
isosceles's Avatar
isosceles
Gerry, that's what I used to do. I guess I'm just not that good at feyeballing it. You have to estimate how much the dist shaft will turn while dropping it in and position the slot in the pump shaft there. Cranking the motor just a tad is MUCH easier. The teeth of the distributor must be something like 90% engaged. A few little turns from the cam gear shouldn't hurt anything.
Old May 13, 2005 | 09:21 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Cool tip. I will try to remember that one the next time I have to do this job. Last time I used the screwdriver method. I must have got lucky cause I got it pretty quickly.
Old May 13, 2005 | 10:43 AM
69'Silver's Avatar
69'Silver
I fought this problem this week and a fellow CF member came over to my house and showed me the best way to get this done. I was off 1 tooth on the alignment to #1 and we could not get the car timed. What he did was to 'walk the distributor around in a clockwise direction' until it line up were we needed it it. By walking around he would lift the dist out just enough to turn it and then drop it back down. This would always line up the oil pump slot each time. We then just kept doing it till it was at the right spot and locked it down and timed. Worked like a champ.
Thanks Dave.
Old May 13, 2005 | 12:15 PM
Pauld's Avatar
Pauld
This thread has come at a perfect time, I am dropping my new distributor in tomorrow. Thanks for the tips
To Distributor install tip
