***UPDATE LS1 in C3
Old May 12, 2005 | 11:38 PM
holley505's Avatar
holley505
Default *UPDATE(pics) LS1 in C3
Ok guys and gals ... the eagle has landed. The motor is in the car. Fits really good.
I will be needing a new hood though.
And I may be adding a set of Chrome B&B headers To my already going over budget bill.
New comp cam and springs install... new converter and flexplate.
Need to have steering rack adjusted... custom power steering hoses... moved the TH350 forward a bit... longer driveshaft... Mostly little stuff.
A few pics to check out.
this.... plus
This...
Which leads to ....
currently corvette manifolds....maybe B&B headers
Should be the First Carb LS1 in Central Florida.
What do you think so far??
Old May 12, 2005 | 11:41 PM
holley505's Avatar
holley505
<img src="http://www.imagesup.com/is.php?i=2291&img=IMG_3628.jpg" border="0">
Old May 12, 2005 | 11:45 PM
lostpatrolman's Avatar
lostpatrolman
interesting.... Have you started the carbd ls1? If so, how does it run? I have yet to see any results of a carbd ls1. Very interesting.
Old May 12, 2005 | 11:58 PM
holley505's Avatar
holley505
Not ready to start yet... few more days...
Old May 13, 2005 | 12:03 AM
isosceles's Avatar
isosceles
Nice work!
I've seen 73 with an injected LS1 at the Corvette Challenge in Bradenton FL, but not carbed.. That should be cool!
Old May 13, 2005 | 12:33 AM
Chuck Harmon's Avatar
Chuck Harmon
A carb'd LS1 is virtually a modern ZL1 in my book. Congratulations!
Chuck
Old May 13, 2005 | 07:40 AM
holley505's Avatar
holley505
thanks... i am hoping to make at least 350 rwhp
Old May 13, 2005 | 08:01 AM
markdtn's Avatar
markdtn
How do the electronics to fire the plugs hook up? Any photos closer to the valve covers?
Old May 13, 2005 | 08:09 AM
Scooter70's Avatar
Scooter70
We're all looking forward to seeing start-up video clips.
Old May 13, 2005 | 08:19 AM
MIKER's Avatar
MIKER
Too cool! Thanks for posting the pictures.
So the TH350 will bolt right up to the LS1? Same bolt pattern?
How about the flex plate?
Why did you have to move the transmission forward? Was there not room to move the engine back to the transmission?
Old May 13, 2005 | 10:30 AM
Nate '69's Avatar
Nate '69
Sweet. Keep us posted!
Old May 13, 2005 | 11:27 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Looking good. Can't wait to see her run.
I ended up extending my PS control ram down 1" and it clears the pan. Hoses are a no brainer. You can probably drop in a C-4 driveshaft. I think they measure 30" to 32".
Old May 13, 2005 | 12:13 PM
holley505's Avatar
holley505
I will get some closer pics tomorrow...
The hook ups are really easy... plug in with factory style harness form MSD. For all the necessary sensors.
http://www.edelbrock.com/automotive/man_chevy_ls1.html
The tranny was moved up about 1 or so for ease of the intall you can see the custom/mod tranny mount in this photo.
http://www.imagesup.com/is.php?i=2293&img=IMG_3633.jpg
The TH350 will bolt right up with the adapter sleeve... ls1 flexplate. I got the sleeve the plate and 3000 stall from HUGHES.
Hp4004 $97.50 plate
HP3795 $43.14 sleeve
GM-30 $308.50 converter
http://www.imagesup.com/is.php?i=2292&img=IMG_3634.jpg
Not sure about the C4 drive shaft... I have taken mine to be lengthened...
I am using the factory C5 power steering and F-body pulley system, having to make a new Pressure hose for the steering rack... YES MY FACTORY RACK NEEDED TO LOWERED.
*** Special THANKS to the Vette Dr. Mike Norris ***
They are doing the work.
http://www.norris-motorsports.com/index.html
Old May 13, 2005 | 04:21 PM
danboback's Avatar
danboback
Can't wait to see this bad boy running!!
Old May 14, 2005 | 12:04 AM
2002z28ssconv's Avatar
2002z28ssconv
Way to go man! Let me know when I can come see it. I saw you on the road in the SS a couple weeks back. If you noticed a black 77 on EE Williams it was me. What did you do with the original exhaust? I need to do headers and Y pipe next. I have major exhaust leakage right now.
Old May 14, 2005 | 12:11 AM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
That's way
Old May 14, 2005 | 07:20 AM
holley505's Avatar
holley505
CHUCK! What's up man...
No I sold the L48 engine and L48 Exhaust manifolds...
I am going to Norris this Saturday... DYNO DAY!
To ***UPDATE LS1 in C3
Old May 14, 2005 | 11:34 AM
nelson71's Avatar
nelson71
Default cool
Cool project. I had been thinking that the carbed intake would work alot better than injection in a C3. Now put an L88 hood on it and you will actually be able to get some cold air to that hot engine.
Old May 14, 2005 | 04:24 PM
holley505's Avatar
holley505
ZO6 BBK Header are just missing the perfect fit.
Back to C5 Manifolds
Old May 22, 2005 | 06:53 PM
Deputy_Dogg's Avatar
Deputy_Dogg
4th Gear
Holley505: I am pondering roughly the same project, but an LS6 aluminum block with a 200R4 out back. Were there any major problems you had with the existing chassis/frame? Did you need to relocate the motor mounts?
On a different note, I have a set of hooker headers/sidepipes that I would like to continue using. Anoyone know if those will bolt directly on to the LS6 (Vortec?) heads? Does anyone currently use the steeriods manual rack & pinion? If so, do you like it?
Drew
