Just installed magnaflows
Old May 17, 2005 | 07:22 AM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
I'ts model # 12226 on the magnaflow site. they fit very well in the horizontal position, so you don't see them, just the two pipes going up like a V. I chose the alluminized instead off stainless because I don't drive it in the winter and rarely when it rains.
Old May 17, 2005 | 07:26 AM
Michel B's Avatar
Michel B
Originally Posted by SkunkApe
The mufflers are 2.25" thick...same size as my (new) exhaust system. So, they should fit wherever the pipe fits.
I'm planning on installing heat shielding on the exterior (underside) of the passenger compartment (right above the muffler) and then wrapping them with the "catalytic converter blanket" sold by Summit. I also plan on wrapping the pipes where they run under the passenger compartment.
I'll post pics upon completion.
I think the sheilding is an excelllent Idea,, it can probably help in drowning under car dronning at the same time..
