Question: from vett down under
Old May 15, 2005 | 07:28 AM
swan's Avatar
swan
2nd Gear
Default Question: from vett down under
I have just purchased a 1980 RHD corvett and am new to this forum so please bear with me?.
My question may sound a bit vague, but could someone tell me what the switch on the console next to the heater slides is. it can be moved forward and backwards with a spring return to centre,it also has a small LED light on it , after looking at the wireing loom it, it is not after market, but standard.. I am guessing maybe! the aireal up down...
Leigh.
Old May 15, 2005 | 08:03 AM
rihwoods's Avatar
rihwoods
Leigh.
On my 78 it is the rear window defogger.When on,that little light is green. Look at your rear window.You should see lines(heating elements).It functions only when engine is operating and has an "auto shut off" after ten minutes.
If you have a power antenna,it will come up when you turn the radio on.
Old May 15, 2005 | 08:05 AM
fl_rider's Avatar
fl_rider
Default That's the ticket..
Old May 15, 2005 | 08:51 AM
cosmicvette's Avatar
cosmicvette
Hey Leigh,
Welcome! do you have any pics of your new vette?
What part of australia are you from?
There are plenty of us aussies on here, I am from NSW.
cosmicvette
To Question: from vett down under
