Id this hole
May 20, 2005 | 12:49 PM
Id this hole
ok , Gary Gruhala and myself are having trouble Id this hole in my rear deck lid , anyone ever seen a hole in the center of the vert deck lid like this one
May 20, 2005 | 12:53 PM
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Usually the hole in the decklid is an indication of a factory hardtop car. Should also have two bolt holes at the corners of the deck lid.
May 20, 2005 | 12:59 PM
They didn't have the center hole in 68. don't think they had it in 69 either. They added it in 70 ir 71, but yes, it is definitely for the factory hardtop. There will be a pin in the middle of the hardtop that goes right through that hole, for a total of 3 pins on the 71 hardtop.
May 20, 2005 | 01:00 PM
I see you've got the holes on the inside corners of the lid, but they should also have stainless threaded inserts. They're not bare holes.
May 20, 2005 | 01:10 PM
ok thats what gary was telling me , he had 68 and 72 and neither had the center hole , so I thought bubba might have drilled that there for his CB ant
May 20, 2005 | 01:31 PM
I was going to say Cell Phone antenna
May 20, 2005 | 01:40 PM
Quote:
That's what it's for.
May 20, 2005 | 03:42 PM
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
probably used a later deck lid on it for some reason if the later ones had the center hole and the earlier ones did not.
