PCV hose routing?
Old May 20, 2005 | 10:43 PM
SkunkApe's Avatar
SkunkApe
Default PCV hose routing?
Anyone have an underhood pic of their PCV hose route? My car is a '74...the PCV is mounted in the forward location of the driver's side valve cover. Hose connects to base of carb (in front). Hose interferes with the upper rad hose...
Old May 21, 2005 | 10:11 AM
SkunkApe's Avatar
SkunkApe
Buehler? Buehler?
Old May 21, 2005 | 10:21 AM
73conv's Avatar
73conv
The pcv hose should go over the radiator hose, I have a pic, but the air cleaner is on the car and it blocks the view of the hose. Not sure how to post pics.
Old May 21, 2005 | 11:21 AM
CGGorman's Avatar
CGGorman
Mine wouldn't help... Holly with the PCV coming out the rear...
Old May 21, 2005 | 12:18 PM
Paul L's Avatar
Paul L
It simply rests on the rad hose. It will do no harm.
Old May 21, 2005 | 06:49 PM
SkunkApe's Avatar
SkunkApe
The PCV hose, resting on top of the upper rad hose, is causing the PCV valve to be (gradually) pulled out of it's grommet. The way it's routed, there is an upward "tension" on the valve. I thought I had it wrong, but I guess I'll wrap some tape around the valve to keep it in place.
Old May 21, 2005 | 08:08 PM
CGGorman's Avatar
CGGorman
Try a new grommet. Mine fits tight.
To PCV hose routing?
