ignition lock
Old May 21, 2005 | 03:30 PM
Sacredgrooves's Avatar
Sacredgrooves
Default ignition lock
took the car out today and stopped for gas. then subsequently spent 3 minutes trying to get ignition to unlock so I could start the car. it has been getting progressively worse and I feel I better go ahead and fix the problem. what do I need to do to repair this? the ignition switch has quite a bit of play in it and I also do not need to put it in reverse to take the key out(4 speed) whichn is incorrect also right?
I found instructions on removing the key cylinder but nothing really on what needs adjusted or if I should just buy a new one?
also, while I spend time acquiring the knowledge/part is it draining my battery to leave the ignition in the position right after lock but before the position that delivers power to the interior lights/accessories? I of course cannot remove my key that way but if nothing else I can still take it out for a cruise in the nice weather and return it to the locked garage.
ps-it is a 69
thanks! Dave
