Calling BLUEL36
Old May 22, 2005 | 11:19 PM
pionexxxx's Avatar
pionexxxx
Default Calling BLUEL36
Still wanting to know the "source" you said you was going to emai me about to find a 68 427 carb
here is the post I had about it http://forums.corvetteforum.com/show...2&forum_id=119
even if it's only a site I need some info on where to get one, thanks
Old May 23, 2005 | 08:53 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
I sent an email to you at the address you listed. I tried to PM you but your mailbox if full.
Call Chicago Corvette. He has a trailer full of old carbs. Wants a lot for each one of them, and then it will need to be rebuilt/refurbished.
Good luck with your search.
Old May 23, 2005 | 12:20 PM
LemansBlue68's Avatar
LemansBlue68
That's a rare carb. Took me 3 years of searching swap meets and ebay to find a good core. I refused to pay the prices the vendors wanted for one which ranged from $400-$600 for just a core. Then you'd still have to replate it and rebuild it if you want it to show. Paragon has a couple of them too. There's also a guy in Texas that has some 7028209 carbs but I don't recall his name offhand.
A more common carb that was the service replacement for the 7028209 is a 7029207 which was the '69 350/350 4spd carb. There's a ton of these around as they were sold over the counter way past the '69 model year.(I have one dated from 1977 but am keeping it). You can have this one jetted to perform just like the '68 carb if a good functional replacement is all that you are after. The service carb is better anyway as it has a metal fast idle cam while the original '68 carb had a red plastic one that tended to harden and crack with time and heat.
I have a list of the correct jets and rods that Lars prepared that I can forward to you if I can find it.
Old May 23, 2005 | 02:27 PM
pionexxxx's Avatar
pionexxxx
Funny, a 69 350/350 carb is what is on this car but I suspect it is hurting performance and needs the 427 one back on there to get some performance back.
Old May 23, 2005 | 02:29 PM
pionexxxx's Avatar
pionexxxx
Bluel36 I still didn't get that email try my new one please it's samtron77v77v@yahoo.com that one will work thanks man!
Old May 23, 2005 | 02:41 PM
pionexxxx's Avatar
pionexxxx
I tried dc rebuilds they don't have hardly nothing and didn't find that carb number at paragon either! so what vendors are you talking about that sell them?
Old May 23, 2005 | 02:54 PM
PRNDL's Avatar
PRNDL
I have a new Edelbrock Qjet. I have removed all the Edelbrock badges so it looks just like a generic Qjet. I am going to stamp numbers on it and make my own "numbers matching" carb!
Number stamping kits start at $5.99
car had 7028218... close, but no cigar
Old May 23, 2005 | 03:10 PM
LemansBlue68
The only differences are in the jetting. The CFM rating is the same regardless of the number. There are also some minor linkage differences but none that would affect performance. A set of jets and rods is a lot cheaper than the correct #'d carb unless you're a numbers guy. I'm afraid I'm guilty of that but have my limits in respect to what I'll pay.
Old May 23, 2005 | 03:14 PM
pionexxxx's Avatar
pionexxxx
I'm set on getting the carb for the car dates don't have to agree with the car but must be a 7028209
Old May 23, 2005 | 03:22 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
I sold a 69 427 to a guy in Michigan that has a 68 390 HP carb that I had restored and put on this car. I tried to find a correct 69 carb but ran across the 68 one. I can't remember the dates on it.
I can hook you two up if this works for him.
Greg
Old May 23, 2005 | 04:04 PM
pionexxxx's Avatar
pionexxxx
Greg
Sounds great! if you need to send something in private don't PM me it's full and the email address on here don't work use samtron77v77v@yahoo.com
Old May 23, 2005 | 04:14 PM
CGGorman's Avatar
CGGorman
Um, so why not "clean house" a little?
Old May 23, 2005 | 05:35 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Here's the info for the carb lead- dunno if he has one, I'll leave that call to you.
Chicago Corvette Supply, 708-458-2500
Old May 27, 2005 | 05:39 PM
LemansBlue68
pionexxxx, I sent you an IM.
LB68
To Calling BLUEL36
