Must wheels be removed...
Old May 24, 2005 | 10:31 PM
SkunkApe's Avatar
SkunkApe
Default Must wheels be removed...
...when bleeding the brakes? If so, can you remove one wheel at a time or must you run back/forth between wheels to do job correctly. I don't own enough jackstands to take off all 4 wheels at once.
Old May 24, 2005 | 10:35 PM
Retro78's Avatar
Retro78
I actually did it without removing the wheels at all. But I have TTII rims that allowed me to reach through to get the rear ourside bleeders.
I did jack the car a little to make it easier to reach the inside bleeders by reaching under the car.
To answer your question directly...Yes you can do one wheel at a time. But..our vettes can be hard to bleed so you may need to make a few rounds.
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
You could do it that way but your'e killing yourself doing so. Buy the jack stands or use wire milk crates or something under the car!
Start with the right rear OUTER bleeder, then the right rear INNER bleeder valves. Then go to the left rear and start the outer one first also. After that you may need to bleed the right side again.
then go to the fronts. Only one bleeder on each caliper there so it's not as much of a challenge to get all the air out.
Old May 24, 2005 | 11:26 PM
VETDRMS's Avatar
VETDRMS
I wouldn't want to get brake fluid on my nice wheels. It will be easier to do it with the wheel off.
Good Luck
Old May 24, 2005 | 11:32 PM
Russ Bellinis's Avatar
Russ Bellinis
Originally Posted by SanDiegoPaul
You could do it that way but your'e killing yourself doing so. Buy the jack stands or use wire milk crates or something under the car.
Jack stands are not very expensive, get the jack stands. Don't trust wire milk crates, if they break, even if no one is under the car, think of the amount of damage they could do.
Old May 25, 2005 | 12:48 AM
kdf1986's Avatar
kdf1986
I would think it would be easier to do with the wheels off. The time it takes you to get 1 wheel off may be less than the time it takes to try and wiggle into position to bleed the brakes without seeing what is reallhy going on.
kdf
Old May 25, 2005 | 01:01 AM
SkunkApe's Avatar
SkunkApe
Thanks all.
Note to mods: Why was this post moved from "Technical"? Is brake bleeding a "General" question?
Old May 25, 2005 | 01:21 AM
VETDRMS's Avatar
VETDRMS
If you look at the forum index it says: "In the Manual Basic Tech"
Yes, brake bleeding is in most manuals. *removed comment*
Old May 25, 2005 | 05:32 AM
ffas23's Avatar
ffas23
If you are going to work on your own car you should have 4 HD jack stands and a good rollaround floor jack. All this can be purchased for under a hundred dollars with all the China imports here today. I don't think I would be able to bleed any of the brakes properly on any of my Vette's with the wheels left on the car and find it hard to believe anyone else could on a early Vette especially with the rear calipers having 2 bleeder screws, 1 inner and 1 outer. The wheels would just be in the way to do it right let alone getting brake fluid all over them.
Fred
Old May 25, 2005 | 08:59 PM
SkunkApe's Avatar
SkunkApe
I have the manual and it doesn't say "remove wheels". It assumes you already have the wheels off (or know to remove the wheels). The manual also assumes you have a lift. I don't have a lift. My question was two part: To remove the wheels and, all four or one at a time. Manual doesn't address this. Real life experience beats the manual every time.
Thanks for your input. *removed comment*
To Must wheels be removed...
