Headers
Old May 25, 2005 | 09:15 AM
skydaddy's Avatar
skydaddy
Default Headers
What type of headers should I run on my '79.
I do not want side pipes. I want good performance and good looks under the hood.
Old May 25, 2005 | 09:36 AM
0013's Avatar
0013
Old May 25, 2005 | 10:37 AM
den(thevetteman)78's Avatar
den(thevetteman)78
If your engine is stock a 1 5/8" headers is good enough. As the brand theres a lot of good headers from just black to jet hot coated, but if you want just something that look and sound good a set of dynomax headers is good enough. That's what i have. Make sure you get a good set of gasket and you will be ok.
Old May 25, 2005 | 10:44 AM
skydaddy's Avatar
skydaddy
how much for a set & is the jet hot the best coating for a "crome" like appearance?
I used to run hooker on my old 4x4 - they made a big difference and sounded great. Did not know for the corvette.
Old May 25, 2005 | 11:44 AM
VETDRMS's Avatar
VETDRMS
I have the Dynomax ceramic coated headers on my '74. The 1-5/8 primaries may be "too small" for my 406, but I won't argue with the results.
Old May 25, 2005 | 12:03 PM
skydaddy's Avatar
skydaddy
I have a 350 in the car now (not original). It has a nice cam in it - not sure what size - in the car when I got it. The plate on the side of the block says bored 0.010 so it should use the 1 5/8" openings.
I learned my lesson on gaskets with my old truck. gotta get good ones and keep the headers tight (but not too tight) to keep a good seal.
All of the smog control stuff is gone - thank God I am in a state that does not have strict controls on that.
Old May 25, 2005 | 12:21 PM
brooksman9's Avatar
brooksman9
St. Jude Contributor
Dynomax here. Looks pretty good. Not exactly chrome but close enough and the price is right!
Old May 25, 2005 | 01:05 PM
grayhook's Avatar
grayhook
hooker ceramic coated headers on mine.
i love'm!
Old May 25, 2005 | 01:07 PM
Scudd's Avatar
Scudd
Dynomax Ceramic Coated here!
Old May 25, 2005 | 01:29 PM
Boofers's Avatar
Boofers
I am running Hooker Competition Headers part number 2451HKR
I had mine ceramic coated by a guy here locally. I know guys that have put POR-15 on thier headers and it only lasts a year or two. Definetely go ceramic coated, protects the headers and keeps temperatures down under the hood. Stainless would be the ultimate but we're talking lots of $$$.
Another thing - switching to headers will have a tendancy to lean out your air/fuel mixture so you will want to jet your carb a little richer. A leaner air/fuel mixture means higher exhaust temps. If your exhaust is too hot the ceramic coating finish will dull and not last as long.
Old May 25, 2005 | 10:04 PM
Fireslayer26's Avatar
Fireslayer26
I just picked these up:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
They may not be the best brand, but I couldnt pass them up for $185!
Aren't they pretty!
Old May 26, 2005 | 08:43 AM
Ganey's Avatar
Ganey
The Dynomax Corvette SB Cerama-Coat headers fit & flow great, much better than is commonly known. Have been rec. them & many have them now.
Fireslayer26
Those are probably made by Dynomax- if not they are a copy.
Hooker Super Comp are also very good.
Old May 26, 2005 | 09:59 AM
Buzzardz_vette's Avatar
Buzzardz_vette
I went with these:
http://cgi.ebay.com/ebaymotors/ws/eB...MEWN%3AIT&rd=1
Couldn't resist the price and they look good. Should receive them today. When they wear out, maybe I can afford ceramic ones...
Old May 26, 2005 | 11:19 AM
captainmorgan's Avatar
captainmorgan
Dynomax Ceramic Coated here also.
To Headers
