ot 283 or 327----
ot 283 or 327----
fellow electrican at work got himself a 1950 chevy truck,w/a v-8.he's not sure what engine is in the truck(truck was in process of a restore) and asked me, its been 25yrs since i had a 327 ,so i told him i would get back to him on tuesday,since im on here a lot i figured id post it and maby someone could help,what are some telltale signs,i can tell him ,,so he can figure out what engine he has? i was thinking of posting the #'s on the pad,,but he told me he couldnt find them..any ideas? all i really can remember about my 64- 327 350 hp was it had the fullie double humped heads,,,,thanks,,,,,,,carl
Location: San Diego - Deep Within The State of CONFUSION!
See what kind of harmonic damper he has. Some 283's have a thin crappy thing that is pressed on and no center retaining bolt.
If you could see the crankshaft flange on the rear it would be round for a 283. The 327 has a pair of notches.
The casting number on the rear of the block will tell you too.
-Mark.
-Mark.
-Mark.
-Mark.
Originally Posted by Michel B
I have a 1967 327, and it has the thin 6inch damper witch is just press fit. To get to the original question, the blocks are almost Identical, I know this is stupid, but a sure thing would be to measure the length of a piston rod.
Received 6,945 Likes
2015 C2 of Year Finalist
the easy way to tell between a 327 and 350 are were the PCV valve is. if it is in the valve cover it is a 350. if it is behind the carb. it is a 327 or 283. also 327 and 283 had the oil fill tube in front of the motor
Let me throw in my 2 cents. As far as the markings go on the heads, there's no guarantee things haven't been changed along the way. I see no reason why the engine could be a 265 instead of a 283 or 327. Has anyone considered that? I actually had double humps on a 265 years ago. Since the man is dealing with a 55 year old truck, anything is possible. Heck it might even have a 302, 305, 350 or 400 that has some old valve covers, intake, and heads thrown on it.
I think the only way to know is going to be get the numbers and search that out.
Carl:
I may be a little lost here. 265, 283, and 327 engines had the oil fill in the front. As I mentioned above, and old intake (one with the oil fill in the front) could have been put on a newer/bigger small block engine.
