I just replace all the front bushings. ball joints, idler arm and tie rods on my 76. Now the ride height is at about 30.5 inches I dont understand. Could someone please tell me how this happens? Even better how do I fix it? Do I have to replace the front springs now to lower it back to 27?
did you stay with the orginal springs. if you did check to make sure the springs are seated correctly. they have cut outs on the springs where they fit in the spring pockets if they are not in correctly it will increase the ride height. also you said you repl. the bushings if they are rubber you needed to tighten them up after everything is back together. if not the rubber bushings can add spring to the ft. end and damage the bushings later. the rubber bushings are bonded to the steel sleve and they can act as a spring and need to be tightened after everything is back together.
The springs are original and the kit came with poly bushings. To my knowledge the springs are seated properly. I just dont understand how I could have a 3 inch higher ride now, "If it aint one thing, it's another" gota love those C3's!!!!
For starters, bushings will not make the car sit 3" higher. Since you reused the front springs, that will not have anything to do with the issue.
That only leaves one obvious thing, the springs are not seated properly in the 'pockets'. I'm in the process of getting things finished with my front end kit. Hope I don't have to tear it apart because of this.
Did you set the car back on the ground before you tightened the end bolts in the A-arms? If you tightened them while the car was in the air it can hold the car up higher than normal.
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
wouldn't it settle out if that was the cause? i thought those end bolts were just to hold the washer and bushing in place.
From: San Diego - Deep Within The State of CONFUSION!
NO!
The two bolts on each control arm that hold in the bushing MUST be left loose til the car is driven around the block and the suspension settles. No question.
Get the car on the ground before tightening those bushings. Causes the car to ride high.
I can see leaving them loose until there is weight on the car if using rubber bushings. I'm not sure if the same holds true for poly bushings. About the only way I can see to do this is to put the car on a lift or on tire ramps. It's not as much about the suspension settling as it is about having the control arm in the proper position prior to tightening. I would imagine that a floor jack could be used under the lower control arm and raised to the proper position and then tighten the bolts. Companies like Van Steel have the advantage of tightening the lower bolts while the car is on a lift.
