tire squeal
Old May 29, 2005 | 06:59 PM
71redskin's Avatar
71redskin
Default tire squeal
my left front tire squeals when i turn to the right at cruising speed... jacked the front up today and inspected underneath... no play at the tire front and back and up and down... idler arm. bushings. tie rod ends all look good... the only thing i noticed is that the rag joint looks ragged... could this cause the squealin and how hard are they to change... also at hard turn to the left, the back of the drivers side tire rubs the inner fender well..
Old May 29, 2005 | 08:49 PM
BigBlockk's Avatar
BigBlockk
Could be that little warning squealer on the break caliper.
BigBlockk
Later.....
Old May 29, 2005 | 10:19 PM
oregonsharkman's Avatar
oregonsharkman
Default tire squeal
For some reason both of my rear tires squeal during acceleration
i haven't figured out whats wrong yet
Old May 30, 2005 | 12:14 AM
GDaina's Avatar
GDaina
Get a front end alignment
Old May 30, 2005 | 12:24 AM
rihwoods's Avatar
rihwoods
Most likely alignment.
Old May 30, 2005 | 08:44 PM
Grinchia's Avatar
Grinchia
Have you checked tire pressure? A little too low and a tire will squeal with little excuse...
To tire squeal
