Valve covers - what height ?
Old Jun 4, 2005 | 03:31 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Default Valve covers - what height ?
I saw some aluminum valve covers on ebay - here's and example of the "tall" version:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33627
they sell these in 'short' 2 5/8" and in 'tall' 3 11/16" height. I am pretty sure that I currently have the shorter version (plain chrome covers) and I like those on ebay a lot better.
What height should I buy ? I don't think there'll be interference issue (f.e. air filter) with the taller version but want to make sure before I buy ...
Old Jun 4, 2005 | 03:52 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
If you don't have roller rockers, get the lower ones.. I personally can only run tall ones without baffles because of my stud girdles..
Old Jun 4, 2005 | 04:14 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I currently have the lower ones with roller tip rockers. I think the taller ones look better - is there any disadvantage with the tall ones ? BTW - $54 seems very inexpensive for cast aluminum covers ...
Old Jun 4, 2005 | 04:29 PM
LFZ's Avatar
LFZ
you shouldn't have any problems running tall valve covers like those..besides they look better.
Old Jun 4, 2005 | 04:36 PM
Twin_Turbo's Avatar
Twin_Turbo
except when you have pivot ball rockers (the roller tips style included), then you may need the drip tabs and low covers to prevent oil starvation at the pivot ball, resulting in galling & seizing.
Old Jun 4, 2005 | 04:37 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Tall ones are for clearance of roller rockers that are a waste of money to install on a street engine.
If you were running a big block, then tall covers MAY be an issue with hitting the power brake booster. People install Hydraboost to solve that.
BTW...$54 is DIRT CHEAP for cast aluminum valve covers. Price a pair of factory cast aluminum valve covers if you want to see expensive. As in $120 EACH.
Dep
Old Jun 4, 2005 | 05:48 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Originally Posted by DJ Dep
roller rockers are a waste of money to install on a street engine.
Dep
Dep, you gotta add that to your sig.
Old Jun 4, 2005 | 06:12 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I have talls and the only thing that truly sucks about them is you have to pull the driver's side cover in order to take the alt belt off on my 77
Old Jun 4, 2005 | 06:33 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Thanks for all the replies, I guess I'm going to buy these. I have to agree with dep, after some price comparison I have to say it really is dirt cheap....
Old Jun 4, 2005 | 08:01 PM
DJ Dep's Avatar
DJ Dep
Your wish is my command. Done!!
Dep
Old Jun 4, 2005 | 11:02 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Just bought my valve covers - they should arrive by the end of this week so next weekend I get to play a little in my garage... I found the cast aluminum covers for $49.99 plus $10 shipping. That seller also had rocker arms (standard style) including the pivot ***** and nuts for $31.99 so I had to get these as well.... I currently have a slight "clicking" noise and I am suspecting my roller tip rockers.... I'll keep you updated on my progress and will post photos once the covers are installed...
To Valve covers - what height ?
