LT 1 heads?
Old Jun 5, 2005 | 03:15 PM
007-8's Avatar
007-8
Default LT 1 heads?
There is a set of LT1 heads online right now for $400.00. You can use any aftermarket intake and carb with those right? I am going to try to build a 400-425 crank hp motor (350) these would be a good buy and match for what I want right? All input is welcome.
Old Jun 6, 2005 | 04:57 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Are you talking about the late-model fuel-injected LT1? If so, those heads are designed for reverse-flow cooling. They can be modified for standard-flow (I'm getting ready to do a set of the cast-iron ones), but it takes some work. We'll see how well it comes out.
