Stock spring length??
Old Jun 7, 2005 | 09:16 PM
corvetteatv7's Avatar
corvetteatv7
Default Stock spring length??
What is the stock length, height, whatever you want to call it of the front coil spring from a '79?
Old Jun 7, 2005 | 10:47 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
5" outer diameter and 15.5" legth (measured from coil end to coil end)
I have two of these in my garage if you're interessted..... they are painted red, nothing that paint stripper wouldn't fix
Old Jun 8, 2005 | 07:59 PM
corvetteatv7
No thanks, there is a motorsports shop in town and i can get regular chevy coils there in any length. I want to lower the car 2-3 inches but the only spring that does so is the one from vbandp and it only drops it about an inch, so this way i don't have to cut them, plus these are cheaper. Thanks for the info though.
Old Jun 9, 2005 | 07:52 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
What height are you looking for ? With the VBP 550lbs springs your front will be at about 27" - that is with the 255-60 tires.... and it is pretty low.
If you cut the stock spring you may not be happy with the ride quality - these are soft springs. Your shocks may not like that....
Old Jun 9, 2005 | 08:01 PM
corvetteatv7
Yea, i was gonna buy the vbandp springs and cut those cause i would like to sit between 26-27, somewhere in there. No positive yet untill i get my tires and wheels. but either way i don't really like the idea of cutting springs, so i think if i can i will just get my tires/wheels, and then see how much i want to lower it and then just order the springs from this place in that height.
Old Jun 9, 2005 | 09:23 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
The 27.2" that I measured is with the 255-60 tires (27.1" dia) - if you install 16 or 17" rims with f.e. a 255-45 or 255-40 tire your front will be lower than 27" with the 550lbs springs.
I would not cut the 550s - I did cut the 460s (3/4 coil) to get almost the same ride height....
To Stock spring length??
