Rear spring help
Old Jun 8, 2005 | 09:07 AM
Phil Zell's Avatar
Phil Zell
Default Rear spring help
What is the process for changing the bolts that attach from the trailing arm to the spring.
Thanks in advance
Old Jun 8, 2005 | 09:58 AM
skydaddy's Avatar
skydaddy
What I did was get the car in the air (mine is on jack stands all the way around) and remove the wheels. Then I jacked the spring up removing the pressure/tension on the bolt. I then removed the castle nut and carefully let the jack down. The spring will have a significant amount of tension on it because it is still attached at the other end. Be careful because when the spring came off the bolt it moved the jack out of the way. The jack that I used was fairly light weight. So position the jack so that you can control it easily, the spring will move downwards and toward the center of the car. Once the first side is down, the other side is easy. For reassembly, just proceed in the reverse order.
I have also heard of some people using 2 jacks and doing both sides at the same time.
Old Jun 8, 2005 | 10:09 AM
SkunkApe's Avatar
SkunkApe
Install a "c-clamp" inboard from the jack (as a stop) to prevent the jack from sliding on the curvature of the spring.
Old Jun 8, 2005 | 01:59 PM
skydaddy's Avatar
skydaddy
Dang, That was the part that I forgot. That is why the jack moved.
Old Jun 8, 2005 | 07:03 PM
Phil Zell's Avatar
Phil Zell
Thanks a million.
To Rear spring help
