Anyone know what this "thing" is ??
Old Jun 9, 2005 | 12:34 AM
Jim W's Avatar
Jim W
Default Anyone know what this "thing" is ??
Does anyone have any idea what this “thing” is? I was trying to pull the turn signal flasher on my 79 C3 when this “thing “popped off. I was located in the lower right side of the fuse panel. In front of the flasher. It is 1 ¼ “ long with 2 pigtails there are 3 set on numbers on it as follows I4665046, 47MF3 and 100 WVDC. Does anyone know what it is and what it does and most important what slots does it plug into
Old Jun 9, 2005 | 12:46 AM
Jim W's Avatar
Jim W
Default Image of "thing"
Opps I hope the image of the thing attached this time[IMG]???[IMG]C:\Documents and Settings\Jim\My Documents\My Pictures\Zach Grad\relay.jpg[/IMG]
Old Jun 9, 2005 | 01:37 AM
chadman's Avatar
chadman
I would like to know this too. I just found one on my 68. I think it might be a capacitor but where did it come from??
Old Jun 9, 2005 | 05:05 AM
RHD '68 L89's Avatar
RHD '68 L89
It is a capacitor, 47 Microfarad, 100 working volts DC. I had one across the brake light switch originally, it is to stop arcing in the contacts which may be picked up by the AM radio every time you step on the brake.
Usually used for radio suppression.
Old Jun 9, 2005 | 09:53 AM
Jim W's Avatar
Jim W
Default Is it necessary ?
Do you think it is necessary whith the new AM FM cd players ?
Jim
Old Jun 9, 2005 | 11:08 AM
Jim W's Avatar
Jim W
Default Picture of "thing"
This is a picture of the "thing" I was talking about in my orginal post. Also this is a test to see if I figured out how to post pictures.
Thanks for the help
Jim
Old Jun 9, 2005 | 11:57 AM
Jim Martley2's Avatar
Jim Martley2
You failed the picture posting test!
Seriously, The "thing" you described is a capacitor and the 2 connectors on the wires wrap around the prongs of the flasher unit and plug into the socket in the fuse box.
To Anyone know what this "thing" is ??
By Michael S. Palmer | 2026-06-03 09:39:05
