79 Rear window openable?
Old Jun 10, 2005 | 02:38 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Default 79 Rear window openable?
Does anyone know of a kit that I can use to make our 79's rear window openable?
Old Jun 10, 2005 | 03:12 PM
page62's Avatar
page62
Forget it. There some kits floating around. They've been out of production for many years, and even if you find one it'll set you back 3 grand...
Did I mention the hinges can bend over time and cause leaks? Like I said, forget it.
Old Jun 10, 2005 | 03:37 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If you can cobble together the necessary parts, the back windows of the '82 Collector cars opened. The '82 assembly instruction manual (AIM) will list the parts and show how the whole thing assembled. The opening hatch can be retrofitted to any of the big back window cars 78-82. This is not a Sunday afternoon conversion, but it isn't impossible either. Expect the glass to be expensive and parts to be somewhat hard to find since they were only available on the CEs. Your best bet may be to hunt the Corvette salvage yards for a wrecked CE whacked in the front and buy everything in one shot. Good luck.
Old Jun 10, 2005 | 03:40 PM
seventyeightcorvette's Avatar
Sounds like the way to go!
Old Jun 10, 2005 | 07:56 PM
lostpatrolman's Avatar
lostpatrolman
Dont the 82 CE's also have a sealing problem due to the crappy hinges?
Old Jun 10, 2005 | 08:09 PM
page62's Avatar
page62
Yes. Like I said, forget it.
If you don't believe me, I have a friend in town with an '82CE. He has lots of foam rubber bits around his rear window to help seal it...
Old Jun 10, 2005 | 08:33 PM
87bob's Avatar
87bob
OK thanks for the honest answer.
Old Jun 12, 2005 | 02:37 PM
copter's Avatar
copter
I've got an 82CE.I can't open to rear window because of the streched out hinges.I'm lucky in that I don't have any leaks.Some of us over on the CE web site are trying to find a pair that are in spec.we have someone that works in a foundry or something and he will make some hinges out of some better meteral.One of the members took his hinges off and was able to bend them in a vice close enough to get his working but it's only a matter of time before they streach out again.It was a very poor design on GM's part.I could get mine to open but I'm afarid if I did it would start leaking
Old Jun 12, 2005 | 02:48 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Yeah -- same problem DesertDawg has with his 82CE.
Old Jun 13, 2005 | 04:18 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
I did get mine almost perfectly sealed up, but I was the one that took the hinges off and squeezed them in a vice....Scary project...
And now without working struts, there is almost no leaks, but I have to manually lift the window.
If I put good struts on it, the hinges will stretch back out....
Best bet is to let this dream go...
To 79 Rear window openable?
