gas tank label
Old Jun 11, 2005 | 02:09 PM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
Default gas tank label
While searching for my tank sticker (build sheet) above the gas tank, I made an extendable mirror I noticed a small GM sticker on the side of the tank(1/2"x3/4"?). It had a part # on it I think. Has anyone seen this small sticker I'm talking about? What is the GM part # for the tank? By the way the tank sticker was there also!
Old Jun 11, 2005 | 08:56 PM
71redskin's Avatar
71redskin
hey that a good idea with the extendable mirror... i will have to bring mine home and see if my tank sticker is still on my 71. but i'll be dropping my tank this fall anyway...
Old Jun 11, 2005 | 09:10 PM
majic1984's Avatar
majic1984
Looks like this?....
Thats just a parts number sticker..
Old Jun 12, 2005 | 02:47 PM
rihwoods's Avatar
rihwoods
Good idea....where was your build sheet relative to the gas inlet ?
Old Jun 12, 2005 | 09:52 PM
Buzzardz_vette's Avatar
Buzzardz_vette
What is the tank sticker and where on the tank do I find it?
Old Jun 12, 2005 | 11:25 PM
68/70Vette's Avatar
68/70Vette
When I dropped my fuel tank, the build sheet was there but it was in very bad condition. It was covered with a layer of oily dust and portions of the sheet were missing. I've brushed away the oily dust and can just barely make out the words with a magnifying glass and a bright light. I can see that my 1968 build sheet was dated May 18, 1968.
Old Jun 13, 2005 | 09:32 AM
stepinup's Avatar
stepinup
the build sheet should be located on the drivers side of the gas tank input,I took the gas lid/bezel off so I could see in there better,push down on the rubber splash gaurd and with a flashlight look to the drivers side.If its there DONT TRY TO REMOVE IT WITHOUT DROPING THE TANK,if its not there Iv heard that it also could be in the dash between the speedo and tach. I guess you have to pull the dashpad to look in there,though I have never found one in that place.
Old Jun 13, 2005 | 10:09 AM
rihwoods's Avatar
rihwoods
Thanks.I looked with extension mirror and did not find anything...( I have a copy of the dealers invoice anyway which has all RPO's listed)...
Old Jun 13, 2005 | 11:08 AM
mvftw's Avatar
mvftw
Yes, I have a '78 and their is the part number on the drivers side...
To gas tank label
