LED's?
Old Jun 12, 2005 | 06:08 AM
redson's Avatar
redson
Default LED's?
Has anyone thought of trying to switch out any lite bulbs out to LED type? www.superbrightleds.com
Old Jun 12, 2005 | 07:33 AM
Pete76Shark's Avatar
Pete76Shark
This is a link to the LED tail light that I purchsed (4 of them) and then proceeded to install inside brand new tail light housings. It is more work then the simple light bulb replacement but I wanted to go to LED's and to many people had bad things to say about the LED light bulb replacement
http://www.littlelogcabin.com/photop...cat=500&page=3
Cheers
Old Jun 12, 2005 | 08:04 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
i put 1157 led lights in and was disappointed by the brightness. They may be a little brighter than incandacent but the big advantage is that they should last a long time.
Old Jun 12, 2005 | 08:42 AM
Pete76Shark
FYI
I also had issues with the tail light pig tails so I wanted to replace them as well. Rather then buy new ones I jusy did the LED mod which from the pictures in the URL you will see replaces the connector.
The people that I talked with on this forum and face to face all said the same thing as TurtleVette. Make sure you can return them...
Old Jun 12, 2005 | 12:02 PM
ESU's Avatar
ESU
I've used some LEDs from ct lumination but only in the interior. The nice thing is they give off no heat , especially for the overhead dome light and come in all sorts of colors.
Old Jun 12, 2005 | 12:21 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I run LED tail lights only in my '61. On my '69 the angle of the socket make them look dim and odd. I wanted to run them to increase the reaction time of the car behind be to have better odds NOT to be rearended!!
To LED's?
