1. Why did you beat the lower A-Arm shaft with a sledge hammer and chisel to get the bushings out. The races were scalloped by the chisel then rough ground on a bench grinder. Also 1/4" chisel cuts on both side of the shaft so it could stress crack in half over time.
2. Why did you put it back in the car?
That's pretty bad. Apparently, Bubba is alive and well working in a machine
shop in Manchester, NH. He sliced into one of my lower CA bushing
bores with a chisel. I had to weld it up and grind it back to new.
... last time I pay ANYONE to work on my car in ANY way.
Bubba:
You stupid mother f**ker, why in he*l would you install new seat covers OVER the old...then try holding them on using the seat track mount bolts????
Eddie
Eddie,
i agree with majic. This one may be one of the best ever, thought the carpeting over of the clutch pedal when changed to auto was a close one.
I still have nightmares about the day I discovered this. I wanted to install missing seat back bezels ('72) when I discovered the original bezels still mounted to the original seat covers UNDER the new seat covers. Bottom covers were stretched around the bottom, then the tracks installed to hold them in place.
Oh...there are more things...but this was the most "Bubbafied" of them all....
Eddie
I would ask "Why is it when someone comes up with a remedy to fix a problem they think they are a genius, but when someone else get the car they think you (Bubba) worked on it?"
Bubba -
Why did you use a coat hanger to hold one of the front sway bar brackets in place.
Why did you use $5.00 in silicone to fill up the front spindle dust cover instead of spending $2.00 to replace it.
Why did you use silver latex paint for the rear leaf, differential, and half shafts.
There are many more but I start to get dizzy over all the stupid things that I had to encounter.
I never did have much Bubba stuff to deal with on the Orange Shark, because it was a very original car when I bought it. Even considering all the mods I've made over the years, I have been known to halt my project for a week or more at a time to make sure that I was doing it as if Zora himself was looking over my shoulder.
That said, I am an amateur wrench for two Porsches, one belonging to me and one belonging to a good friend. Both of these cars were previously maintained by the same guy, who shall remain nameless (because I don't know the German word for "Bubba"). My questions for him would be:
1. If your transmission bolts were too long for the application, why did you thread a couple of nuts all the way up to the head and have the whole assembly stick out? Why did you not (a) cut the bolts to a shorter length or (b) buy the right bolts in the first place? Isn't a transmission mounting bolt considered a critical drivetrain part?
2. If the clutch cable had too much play in it, why did you stack up about 10 washers against the sheath instead of properly adjusting the cable inside the sheath? (I may soon find out the answer when I try to reinstall that part.)
3. Why did you spend good money on a nice stereo front-end and use speakers that would embarrass the stingiest denizen of the cheesiest swap meet? For that matter, why was all the stereo wiring installed using vampire connectors?
4. Is there a reason why some of the bolts on my car are SAE and some of them are metric? Pick a team, please. I have two sets of tools... I just don't think it's necessary to use them both at the same time.
Why did you cut the sholder harnesses?
Why did you swap the seats when you put in new carpet, (passenger and driver, wrong color carpet), and how the hell did you bolt in the passenger seat?
Oh yea why didn't you put the A/C back when you swapped the engine?
