70 What's it worth
70 What's it worth
OK boys and girls,
Came across a guy trying to sell a 1970 coupe. Original owner w/POP, dealer invoice, complete history. It's a 52000 mile Laguna gray(repainted Mercedes gray),with black vinyl.The car was hit and repaired(good work)front left,also in rear, back in the late 70's.No damage to the body now! Bonding lines aren't visible. Paint is dull, but probably can be detailed.Car is all there down to the box the license plate frames came in! Appears to have all original glass,have codes just haven't checked yet.Body seams line up good, except the T Tops there is very wide space between the two.Maybe needs adjustment only.The interior is in great shape with new carpets, no tears or rips.Everything works fiber optics,clock,AM/FM all gauges.Vacum is strong, wiper door and headlights work fine.T Top bags where in the back!
The motor is a 350/350 that has also been painted, yes paint on the #pad, but the numbers are there and do match (block,intake,carb.,trans,etc). On 70's was there an emision sticker on the firewall, if so it's been painted over.Also no blue GM vin sticker on the door painted over also? Windshield vin plate is original untouched. Checked the head thru the oil fill cap,it matched.Looks like some suspension work has been done, probably do to the front left damage.Tires are radials on the original wheels in good shape.Also, the car does have air conditioning!
Didn't get to drive the car yet, but I was told that it drives and stops straight?
I'm relatively new to the Corvette hobby, just bought an original 71BB w/ 17,000 miles, maybe one for show the other to drive? Like to hear what everyone has to say!Thanks in advance kdg490
Driving and stopping straight you can fix - I'd check the frame in front of the rear wheels for rust through, and perhaps the windshield framework.
There was a small sticker on flat spot near the hood latch on the drivers side. There should be a small paper sticker on the door near the latch with the VIN, and a riveted code tag on the driver's door (near the hinge) with paint and interior color codes.
I'm not sure it's legal for someone to own more than one Vette!! Anyway, most folks on this forum agree that 1970 is the finest and best looking year for Corvettes... They will probably try to deny this fact, and state that other years are better - giving phoney reasons, etc...
On 70's was there an emision sticker on the firewall...
Z-man is totally right. 70 is the finest year and there is no denying it!
As for value for this 70 you have described..thats a tough one.....
It has full documentation and history and 52000 original miles....thats a real plus.
Its not the original colour or paint colour....however sounds like it may be the paint done when it was repaired of the accident damage as the paint is faded you mention.
350/350, so must be a manual. Numbers matching.
Well Im sure someone on this board can help you out....Im guessing its worth somewhere between $20K and $23K.....whats the owner asking? Isn't that a gage of how much its worth! Its worth as much as someone is willing to pay.
Yep. 1971 would be the last of the best. Last year chrome metal pedal mouldings, chrome plated plastic fresh air vents & *****, green phosphorescent lettered gauges, fiberoptic light monitoring system, non retractible lap belts, metal backed inside mirror, chrome plastic plated radio *****, , manual pushbutton seat belt light/no buzzer.
It also happens to be the last year manual transmission cars outsold automatics!
That sure is a nice looking 70 (pic in your avatar).
Early Shark: thats some great info:
Forgot to mention re: price. You might check some recent Corvette magazines (Vette & Corvette Fever) to see what similar cars actually sold for in the auctions. I think they have listings near the front. That way you could get a pretty good starting point regarding price...
Assuming no rust problems,I think it would be a very good deal at $18k-$19k,a reasonable price at $20K-$21k or so, and not a good deal over $23k or so. Even well repaired damage makes the car worth a couple thou less than a "never hit" car,imho. Hope this helps.
John
John
St. Jude Donor '05-'06-'07-'08-'09-'10
Originally Posted by TexasMadMan
Hey, I'm just a novice here. I know factory AC didn't come with the 370 HP engine. Could you get the air with the 350 HP engine?
This sounds like a decent car. I would check the usual frame/birdcage areas.
The documentation is a huge plus to resale.
These '70's have really been skyrocketing lately.
As for differences between '70's and '71's, most of the changes are in the engine options. The HP rating really goes down on the '71. There are other slight differences involving the front grills, side grills, color options, etc.
Good luck.
Tom
thanks guys and Hello
Thank all of you for your advise,and hello to all the forum members.I'm a rookie! As I mentioned earlier, I not only new to the Corvette hobby, new to the club, forum thing as well.
I wasn't aware of any rule where you couldn't own more than one vette, I'm looking one of each! HA HA (C 3's only of course)
Man did I find the PERFECT 71 to start off with!!! 17,000 real original miles.
Back to the 70 for a minute, to all you 70 lovers,the car did run sweet!Started right up, after sitting for months. I did check as best as possible for rust, and the frame looked fine, but there was some evidence of rust @ the lower passanger windshield post. Also alot of undercoating @ each wheel well,under hood, muffler area,spare tire carrier.Forgot to mention before you guys are right its a 4 speed,L46 with air, and vinyl int.
The owner is looking for somewhere from 20 to 25k, I think more like 18k.Can you really repair competely a hit car? Front damage was from a slide into high curb, rear end from rear collision with another car. Just being hit before scares the H out of me!
I'm waiting for a copy of the dealer invoice, and I'd like to drive it! Perhaps, take a deep breath, clear my head a little, and come down from the treasure hunt a little? Thanks again kdg
