smog stuff
Old Jun 18, 2005 | 04:14 PM
logansrun73's Avatar
logansrun73
St. Jude Donor '14
Default smog stuff
i want to remove my smog stuff the only problem is the pipes going into the manifold are stuck pretty good. I got the hose part that is connected to the pipes off. So I was wondering if I could just cap that main tube off and what size fitting that would be. Thanks I'll check soon I'm in the garage now.
Old Jun 18, 2005 | 05:10 PM
logansrun73
St. Jude Donor '14
No answers yet? Please help!!!!!!!!!!!!!!!!!
Old Jun 18, 2005 | 05:39 PM
onaqwst's Avatar
onaqwst
what type of smog stuff do u have..... i need a setup for a 77 i think it's the AIR setup........ if it will work for my 77 do u want to sell it off?
b
Old Jun 18, 2005 | 05:52 PM
logansrun73
St. Jude Donor '14
No not right now. The motor is seized up on it. I just want to remove it for now. Do u know can I just cap off the pipe that all the little tubes connect to for now it is were the rubber tubes connect to .
Old Jun 18, 2005 | 06:02 PM
chris75stingray's Avatar
chris75stingray
is the check valve still on it . if it is then it doesn't need to be capped.
Old Jun 18, 2005 | 06:24 PM
logansrun73
St. Jude Donor '14
Is the check valve the thing that the rubber hose is clamped to?
Old Jun 18, 2005 | 06:49 PM
LYLE's Avatar
LYLE
Its a pipe thread and I think you need a 3/4" pipe cap. Take the valve to the hardware and check the size. THe tubes may burn off if left this way for years.
Old Jun 18, 2005 | 06:54 PM
logansrun73
St. Jude Donor '14
Will the car still run good if I do this?
Old Jun 19, 2005 | 09:33 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...IMHO I'd leave the original pipes in THOSE manifolds and hunt up another "non-A.I.R. set" from a '74 L-48 automatic, '75 or '76 Corvette or '77-'79 L-48 automatic Corvette. They are fairly cheap & plentiful. You may end up destroying those threads and make them unuseable unless you "weld" the plugs in(which I've seen neatly done)if your threads strip out.
To smog stuff
