What is it?
Old Jun 19, 2005 | 12:27 PM
007-8's Avatar
007-8
Default What is it?
I have a '78, I found directly below the steering column at the base of the dash a ****. I pulled it down and could here vacuum escaping. What is it and what does it do?
Old Jun 19, 2005 | 12:28 PM
fl_rider's Avatar
fl_rider
It makes your headlights pop up, if it works......
Old Jun 19, 2005 | 12:29 PM
JungleCat's Avatar
JungleCat
St. Jude Donor '05 thru '26
If it is what I think it is, once your headlights are in the up position, the switch, when pulled, will keep them in the up position.
Old Jun 19, 2005 | 12:31 PM
007-8's Avatar
007-8
Really, I wonder if thats the reason I get them to pop up. Would make sense. Although I pulled the headlight switch and pulled the **** and they didn't come up then so I'm geussing it doesn't work. Thanks
Old Jun 19, 2005 | 01:34 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
If you hear hissing, one of the hoses has become disconnected, or possibly the switch is broken/cracked. Chuck
To What is it?
