Block Marking?
Old Jun 22, 2005 | 09:18 PM
wnmech's Avatar
wnmech
Default Block Marking?
I am tearing down my doner 78 350 engine for my 77 corvette. I was able to positively sipher most of the casting numbers off of the block and heads which definately identify it as a 78 full size chevy. Anyway on the side of the block in large bold stamping is a 010 I thought maybe it might mean a 10 over rebuild but I am not sure. I pulled out one of the pistons and there was no marking on it indicating oversize and the rod bearing had no oversizr mark on the inside of the bearing. I have not yet put a micrometer on the piston or bore or crank but I was wondering if any of you professionals know what that mark means? Thanks again for all of your help out there.
Old Jun 22, 2005 | 09:38 PM
RHD '68 L89's Avatar
RHD '68 L89
Is it stamped or cast into the block?
010 usually refers to high nickel content block which is a good starting point for an engine but I think it is part of the part/casting number.
Old Jun 23, 2005 | 02:05 PM
wnmech's Avatar
wnmech
Default block marking
It is cast into the block kind of in the area where the engine mount attaches to the block
To Block Marking?
