Replacing shifter, How difficult
Also would like to take off power steering and replace oil pan, anything to look out for.
Thanks in advance for any help.
Clearances are close and hand space is at a premium. Remember to install the lever from the top (inside of the car). If you use a competition plus, it is hard to set the stops correctly because there is little space to swing wrenches.
Good Luck!!
