Replacing Fuel Pump
Old Jun 24, 2005 | 10:41 AM
c3andc5's Avatar
c3andc5
Default Replacing Fuel Pump
I have a 73 (350 SB) and want to replace the fuel pump. I've not done this before, but I learn quickly. Does anyone have some easy to follow procedures, cautions, etc. that I might use for this procedure. Thanks in advance.
Old Jun 24, 2005 | 10:48 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
the fuel pump rod can be held in place by removing the small bolt in front of the engine pass side just in front of the fuel pump and replacing it with a longer one tightened finger tight... you can get at one of the fuel pump bolts through the tire well with a long extension, its the easiest way.....good luck its not technicaly hard just messy and a PITA
Old Jun 24, 2005 | 01:06 PM
GTR1999's Avatar
GTR1999
Bob said it well. Use some good RTV on the gasket too and don't forget to replace that bolt in front!
Gary
Old Jun 24, 2005 | 04:08 PM
mvftw's Avatar
mvftw
The bolt way is ez, but mine is eaiser...first go to TDC (gives you more room for the rod to be pushed back), then just take out the pump. I would replace the short 'S' fuel hoses (get them from a corvette supplier), if not put a bolt in or use a vise grip (not to tight). Once out, get a hacksaw blade and put it in front of the rod, now just use the blade as a shoe horn, just follow the pump plunger down, then pull the blade out...
Old Jun 24, 2005 | 05:51 PM
c3andc5's Avatar
c3andc5
Gary
Gary, can I assume that a new gasket comes with the fuel pump? What bolt in front are you referring to?
Chris
Old Jun 24, 2005 | 10:24 PM
bobs77vet's Avatar
bobs77vet
Chris
no mine didn't .....look at the front of the engine just in front of the fuel pump....horiziontatly (sp?) there will a bolt tightened down not holding anything....thats the one
Old Jun 25, 2005 | 05:54 AM
c3andc5's Avatar
c3andc5
Thanks Bob
guppie's Avatar
guppie
St. Jude Donor '08
I just put grease on the rod to make it stay in place
To Replacing Fuel Pump
