strange tail light prob - help
Old Jun 24, 2005 | 11:15 PM
fcoppola's Avatar
fcoppola
Default strange tail light prob - help
This is on a 74 - My drivers side tail light does not come on BUT its NOT the bulb because the brake light and directional work fine. So this would indicate it is not a bad ground, or a bad bulb. I have done a search on here and have not seen this exact problem. The passenger side is perfect.
I have seen some talk about a piggy back cable .. does this apply to a 74? Its dark now when I noticed it so I have not had a chance to get under and look at it.
Any help is appreciated.
Old Jun 24, 2005 | 11:21 PM
Marks69BB's Avatar
Marks69BB
Default Check the bulb!
The 1157 is a dual filament bulb, one for the stop/directional and one for the tail light. Sounds like the filament for the tail light is broken in two. You should be able to hold it up to the light and see if it is broken. Replace it and you should be good to go!
Old Jun 24, 2005 | 11:43 PM
onaqwst's Avatar
onaqwst
terminals might need to be cleaned also......
b
Old Jun 25, 2005 | 09:32 AM
SteveG75's Avatar
SteveG75
Old Jun 25, 2005 | 10:49 AM
docmow's Avatar
docmow
2021 C5 of the Year Finalist - Unmodified
on my 76 the ground strap in side bulb socket was was broke so it was grounding throughthe wireing or the outher
Old Jun 25, 2005 | 05:02 PM
BlkBird's Avatar
BlkBird
Old Jul 3, 2005 | 09:29 PM
fcoppola's Avatar
fcoppola
double filament bulb ... who woulda thunk it.
Replaced the bulb and all is good again.
Thanks everyone.
To strange tail light prob - help
