Eckler's could not confirm if it was 3" or 4" ring? E-Bay has them from $24 to $50. up to 3". I just need to make sure I am getting correct one and tyring to confirm that they didn't make a 4" ring for my rim.
jim
Someone can correct me if I'm wrong... but if I remember right, 67s had 15X6, 68s had 15X7, and 69s and later had 15X8 rallys. The trim ring for 67s is flat on the outer bead, 68s and later are rounded. For some reason when they widened the wheels in 69, they didn't make a wider trim ring, so u can tell whether it's a 7 or 8" wheel by just glancing at it... there's a big gap between the inside edge of the trim ring and the wheel.
I just measured my original trim ring on my 15X8 wheel, and I'd say it's 3-1/8" deep... so I guess that would make it a 3" wide trim ring.
