Starter woes
Old Jun 28, 2005 | 11:59 AM
Gforce454's Avatar
Gforce454
Default Starter woes
I have owned a 1971 454 Stingray for 17 years. I have burned up several starters and have always had heat-sink issues with the starter not wanting to easly crank the engine after a few weeks or months of use. I've used an original styled heavy duty delco starter that weighed a ton&heavy duty Starter Solenoid with stock stainless steel heat shield, mini-starter made in china, discount auto parts rebuilt starter, all failed after limited use. When I remove them they look fine but they must be burned up inside. I test them out of the car and they fail to work. I've been looking at these links below. Anyone have any good ideas. I hate to blow 250 bucks on a pricey hi-po starter just to have the same outcome as I did with these cheaper units. I've been using the staggered bolt starters because the inline bolt starters appear to use a hole in the block that is never been used and has years worth of grease and dirt stuck up in it. Also I like using the trans-converter cover and feel the inline bolt starter would not match the cover well.
I like this one best.
http://www.partzfinder.com/Chevy_SB_...vr-5323-os.htm
Second choice.
http://www.partzfinder.com/Chevy_SB_...r-5323-mos.htm
These are some I've been looking at.
http://www.murraysauto.com/store/mySearchResult.cfm?parentcategoryid=&pro ductID=14011&showDetail=1&categoryID=0|& vendoridtodisplay=0&filterFor=starter&co llection=
http://www.autozone.com/servlet/UiBr...rameters=Chevy
http://www.partzfinder.com/High_Torq...pfp-6449-n.htm
http://www.dbelectrical.com/ministar...istarter.shtml
http://www.car-stuff.com/chevystarter.htm
http://www.tommyjohnsons.com/catalog...0b40eb4667fb93
Interesting starter saving add ons.
http://www.behrents.com/Merchant2/4....ating-products
http://www.oldengine.org/unfaq/solenoid.htm
Old Jun 28, 2005 | 01:41 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
I have the same problem but with a big block Chevelle....re-built the starter & wrapped it in Thermotech's starter heat shield! It works ok. The Corvette is even tighter space wise & may create more heat..I am not sure how it will work for you. Just a thought.
Old Jun 28, 2005 | 02:32 PM
Gforce454's Avatar
Gforce454
What type of starter was it?
Old Jun 28, 2005 | 06:57 PM
007-8's Avatar
007-8
Have you tried shimming your starter out, it sounds like you might be fring with amps. Perhaps being to close to the flywheel is adding extra stress and driving the amp load up. Just a thought.
Old Jun 28, 2005 | 08:07 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i'm using a pro form hi torque mininstater from Scoggins Dickey $149 and it works fine and clears the headers easily....i think these shields and wraps are "nonsensical" to me since they prevent any real cool down options after the engine is turned off.....i like the ministaters that hvae better air flow around them since they are smaller....
Old Jun 30, 2005 | 02:41 AM
Gforce454's Avatar
Gforce454
Thanks for the info. I am going to look for a starter that will put up with my BIG BLOCKS warm ways! I have a grave yard of 3 dead starters. They are toast.
Old Jun 30, 2005 | 02:44 AM
Gforce454's Avatar
Gforce454
Yes and it got toasted anyway. 454 + corvette = HOT SINK STARTER!
To Starter woes
