Flare nut wrenches?
Old Jul 2, 2005 | 12:28 AM
SkunkApe's Avatar
SkunkApe
Default Flare nut wrenches?
I have a "cheap" set of flare nut wrenches. When used on stubborn fittings, the wrenches tend to flex and eventually slip.
Does anyone have a quality set of flare nut wrenches (Snap-On, MAC, etc.) and do these wrenches flex under pressure? I'd like to know before I bite the bullet and spend $$$ on a good set.
Old Jul 2, 2005 | 01:03 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I bought a set from Craftsman a while back. No they don't flex under pressure.
Old Jul 2, 2005 | 01:05 AM
BigBlockk's Avatar
BigBlockk
Snapon and Craftsman have good wrenches but remember you're not suppose to take cylinder heads off with them.
BigBlockk
Later.....
Old Jul 2, 2005 | 01:27 AM
rosslato's Avatar
rosslato
Old Jul 2, 2005 | 01:35 AM
Corz's Avatar
Corz
Cruise-In IV Veteran
Originally Posted by rosslato
I love those wrenches.
Old Jul 2, 2005 | 09:20 AM
KenSny's Avatar
KenSny
Flare-nut wrenches are NOT supposed to be used in all situations as you would a standard open-end or box wrench. They are mainly designed for tubing/pipe nuts such as you find on fuel lines, etc.
Old Jul 2, 2005 | 09:28 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
fuel and brake lines should have significantly less torque, hence the flare nut wrenches... if they are tight enought that they make the wrench flex, they are definitely too tight!
Old Jul 2, 2005 | 09:38 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
I've had a set of relatively cheap Kay Bee tools flare nut wrenches for decades. I use them as they're designed....for brake and fuel lines only. I never "crank" on 'em or abuse them. They'll last me forever.
Reminds me of a story. A neighbor asked to borrow my Snap On "clicker" torque wrench for a project. I went down to his house one day and found him using it as a breaker bar.
Amazingly, he didn't screw it up too badly. I had it recalibrated.
If you're cranking on flare nut wrenches enough to bend them, something isn't right.
The moral to the story is "don't abuse your tools" Chuck
Old Jul 2, 2005 | 10:14 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Chuck
I have a set of Craftsman line wrenches. They seem to be pretty good quality and have been used several times now.
If I would have caught him using my torque wrench like this I would have probably had to say something right then. Never use a torque wrench as a breaker bar.
Old Jul 2, 2005 | 10:55 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Me too.
Old Jul 2, 2005 | 11:43 AM
stingr69's Avatar
stingr69
I have some cheapies. They suck. I put a vise grip over the outside of the tool in an effort to keep them from opening up and it helps save the nuts. Some times you just gotta make a new line though.
-Mark.
Old Jul 2, 2005 | 06:41 PM
Sharky Guam's Avatar
Sharky Guam
BigBlockk
Later.....
why not...?
I sometimes cheat and use them on long studded nuts....it's much better than an open ended wrench.
Old Jul 2, 2005 | 08:41 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
I like my swagelok racheting flare nut wrenches
Old Jul 2, 2005 | 11:51 PM
SkunkApe's Avatar
SkunkApe
I'm not a dummy. I know how/when to use flare nut/line wrenches. And, anyone who regularly works on 30 yr. old cars knows that stuff gets stuck, including brake lines, bleeder screws, radiator/transmission fittings, etc. If a flared fitting is "stuck" and you're using your flare nut wrench on it, and the flare nut wrench flexes, then what the "F" are you supposed to do??? Hence my question.
Thanks for the replies.
Old Jul 3, 2005 | 12:29 AM
Hitch's Avatar
Hitch
Another vote for Craftsman... I've actually got two sets.. One of the dull shine and another chromed.. Although has anyone else noticed that the recent tools from Craftsman seem to not be as "ROBUST"... ie.. I was putting some medium torque on a nut and it left marks on the wrench's open end...Dave..
Old Jul 3, 2005 | 12:49 AM
Ironcross's Avatar
Ironcross
Your brand names have a full warrantee with them. Cheap imported wrenches are a waste of money and sometimes could hurt you.
Bloody knuckels.
Old Jul 3, 2005 | 12:57 AM
The Dude's Avatar
The Dude
Personally I have never met a flare wrench that was worth a crap--Craftsman, Snap-On or whatever. They ALWAYS make a simple job a complicated, nut-rounding, knuckle-busting exercise in mayhem and colorful language. Waste of money, IMO.
To Flare nut wrenches?
Old Jul 3, 2005 | 01:47 AM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Two words: vice grips.
Ran into the same problem with both transmission cooling lines and brake lines. They freeze solid because some gorilla overtightened them. So, the line wrenches flex and end up rounding the nut. In that case I find it's better to get vice grips with the flat mouth and clamp it on. Just not so hard that it deforms the line, just get a good solid grip on the faces of the nut.
Old Jul 3, 2005 | 02:09 AM
Ironcross's Avatar
Ironcross
I can sympathize with you on this subject of overpriced, but never attempt to use anything but high quality flare nut wrenches on a Rochester FI unit. Too many now overpriced parts and lines that can be screwed up that will create a very unsightly underhood appearance. And NEVER vice grips. Actually I believe they are correctly or commonly called line wrenches
Old Jul 3, 2005 | 07:59 AM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
I have broke my Craftsman line wrenches in various sizes over the years, but have never had an issue where I'm rounding nuts off from flex. Try some heat on the nuts if they are real stubborn or rusted in place.
