I just came back from a cruise to the mall and notice moisture in the carpet, passenger side. I pulled up the carpet and there was anit freese (green oily stuff) pooled on the floor (see "A"). But I don't see where it came from. no signs of leakage down the walls (see "B"). Earlier in the year I did notice a film on the windsheild at night; I know the heater coil is the problem here. How related are these events. What to do?
When I make an order for a heater core, what else should I have on hand to fit the problem? ie. hose, clamps, etc. I don't want to keep waiting for parts.
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Dr. Rebuild has a very good seal kit. While you're in there, you probably should check the seal on your passenger side vent door and re-seal it too.
I'm currently going through all of this. I need to remove the dash to re-dye and re-seal the vent system. It'e a big job, but nothing has been too difficult, just time consuming.
If you're goona tear deep into it, do yourself a favor and remove the seats, they just get in the way.
my p.s.vent door needs a new seal .how do you get the door out and where do i get just the door seal ?
Remove the kick panel. The actuator assembly is held on by two bolts. Remove the vacuum line to the actuator and then the two bolts.
Pull on the actuator assembly and remove the clip that holds the arm to the door. Once that and the spring are disconnected, the actuator will come out with it's bracket.
To remove the door, press the top hinge pin down (it's spring loaded) and pull the top of the door towards the interior until you can lift the door from the lower hinge pin. Pretty straight forward.
The door seal is sandwiched between the two panels of the door (riveted together). You will have to drill out the rivets to remove the seal. The Dr Rebuild kit contains the new seal, rivets to put the door back together and a new press on nut for the actuator-door linkage.
While you are in there, clean out the passage and be sure that the seam between the forward wall of the plenum and the fender (the seam you can see when you look through the vent from the center of the car) is sealed. The plenum is a part of the fender and if that seal is broken, heat from the engine compartment will come into your A/C system, which will degrade it's performance.
1) 5 minutes with "stop leak". (This worked for 8 years for me with no side effects).
2) 1 hour to replace heater core if you don't have that fancy, schmancy air conditioning...
If you don't drive it in the cold, just plug the connections at the water pump and intake, take off the hoses, and bask in the efficiency in which you handled the repair...
(don't ask me how I know, lets just say I got lots of practice on this particular repair...)
Saw a neat trick on how to dothis on another thread. Get a bicycle tire from wherever (just make sure it is the smallest diameter tube you can get. Cut the tube six inches from the valve on either side.
Attach the sides of the valve to the heater core lines. The tube I got worked OK on the larger feed with cable ties. For the smaller one, I had to build up the diameter with electrical tape to get a good fit.
Use a bicycle pump to pressurize the tube/core.
Immerse the whole assembly in a bucket of water and make sure your tube to core connections are sealed.
Leave it overnight in the bucket. If the tube is still pressurized after a day, the core is good. If not, you should be able to see the leak point by the trails of bubbles.
Works well, I have mine in the utility sink as I type.
