Shifter console trim
Old Jul 13, 2005 | 09:44 PM
busterpelvis's Avatar
busterpelvis
Default Shifter console trim
Just received new console trim, how do you cut for window& def switches?? Thanks
Old Jul 13, 2005 | 10:20 PM
kona's Avatar
kona
My console came precut. Is there any markings on it? Did you order the right one?
Kona
Old Jul 13, 2005 | 11:07 PM
mark79,80's Avatar
mark79,80
The underside of the console should be marked where the cuts are
needed. I used a dremel tool to make the cuts. Used a cutting wheel
to make most of the cuts and a small grinding bit for the corners.
The consoles are sold be GM uncut. Many of the corvette vendors
offer precut ones for an additional charge.
Old Jul 14, 2005 | 08:23 AM
ram82fire's Avatar
ram82fire
I cut them on my bridgeport using a small end mill !
Geo
To Shifter console trim
