Check Engine Light
Old Jul 12, 2005 | 11:48 PM
cmittag's Avatar
cmittag
7th Gear
Default Check Engine Light
I have a 1982 Collector Edition. When I turn off the ignition the check engine light comes on. Any ideas why? Is there a easy way to correct this?
Old Jul 13, 2005 | 12:48 AM
Bangkok Dean's Avatar
Bangkok Dean
Welcome to the C3 gang The most knowledgeable guy for 82s is Twin Turbo, he may chime in here or some others that have experience with this problem.
Old Jul 13, 2005 | 04:51 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Is the light coming on? and staying on with the key removed???
Old Jul 13, 2005 | 08:18 AM
cmittag's Avatar
cmittag
7th Gear
Light goes out with ignition on and running and comes on with ignition off and key out.
Old Jul 13, 2005 | 08:32 AM
Twin_Turbo's Avatar
Twin_Turbo
The most plausible cause would be that someone has changed the 12v switched power lead to a non ignition switched source, either directly to the battery orjunction block right next to it or in the harness between the ecm and fusebox.
The ECM has 2 power leads, an ignition switched main power lead and a ram power lead which is non switched off the junction block, this one is for the ram memory, an orange wire sometimes with an inline fuse. This one seems fine since without it the CEL won't light at all.
Is this something that happened recently?
Is the CEL the only thing that has power to it with the ignition off?? If not, it could also be your ignition switch
Old Jul 13, 2005 | 10:41 PM
cmittag's Avatar
cmittag
7th Gear
I'm using a battery disconnect to keep from bleeding the battery.
The car has not been worked on and this started before I installed the disconnect.
It started about six months ago and would go away for a while. Now the light is on when there is battery power and no key in the ignition.
Nothing else is powered with the ignition off.
Old Jul 13, 2005 | 10:44 PM
cmittag's Avatar
cmittag
7th Gear
When I turn on the ignition the light goes off.
Old Jul 13, 2005 | 11:06 PM
Bangkok Dean
Now that sound interesting
Old Jul 14, 2005 | 08:10 AM
cmittag's Avatar
cmittag
7th Gear
Is the ECM the box forward of the Battery?
Old Jul 14, 2005 | 08:28 AM
Twin_Turbo's Avatar
Twin_Turbo
yes and the ESC is bolted to the back of the ECM (on the firewall behind the seats side)
Old Jul 14, 2005 | 10:59 PM
cmittag's Avatar
cmittag
7th Gear
Not to sound dumb, but what is the ESC?
To Check Engine Light
