Interior still hot!!!
I also just ordered the thermo tec self adhesive insulation from summit, I'll try it on my 79 where the earlier cars have that shielding and see if it helps. Hope it sticks to the underside of the car OK.
ESU in NY.
Rich
When you go to a/c max, it closes the outside "fresh air" door (located outside of the car, right side of airbox). Since the system is no longer able to pull air from the outside, it opens the inside kick panel flap to allow the inside air to be recirculated.
a/c max is the only time that those two flaps are in that configuration. All other climate settings use outside air. FYI - a/c max also closes the hot water valve.
Will be cleaned good and will prep the plastic.
ESU
. ESU
. ESU
Rich
Footwell carpet before Reflectix = 110 F
After installation = 95 F
The interesting thing were exhaust pipe temps near footwell = 462 F and exterior surface of footwell =165 F....(the pipe being 4" away)
Based on this result I will not attempt to install Thermotec on exterior footwells....instead,I'm going to make a sheetmetal heat shield for the exhaust pipe (24" long) leaving 1" space between pipe and shield...the shield will be between pipe and footwell...The Reflectix cost $20 for a 48"x 10 Ft roll....part no. BP48010...it is for interior only as it's temperature range is -60 F to +180 degrees F....
Pic of "early shield...
I just finished my interior rebuild which included gutting the interior and laying dound sound deadener (dynomat clone), a layer of reflectix and then the carpet set with jute backing. That significantly cut down the footwell temperature, but I was still getting no A/c benefit.
Long story short, I have a vacuum leak in th eline to the heater hose valve. When we applied vacumm to the valve (using a mityvac), the A/C went cold again.
I know many people are putting in ball valves to cut-off the flow, but this looks a bit odd to me under the hood so me and a buddy improvised a slightly different (yet still a bit bubba) solution.
We tee-d off one of the vacuum lines from the carb to the thermal flaps on the air cleaner housing. Now, when th eengine starts, full vacuum is applied to the valve and it shuts off the flow. The only downside is that when you floor it, the valve loses vacuum and the hot water starts flowing into the heater core.
It's still a bit bubba, but atleast it's stealthy bubba!
I'll fix the vacuum line, but atleast I can now drive with real A/C.
By the way, with the hot water shut-off, the A/C vents blow about 57 degree air into the cabin. I find myself flooring it every once in a while just to warm up.
Well,don't do this.....
Tried a short cut by tacking shield to pipe...now I have to remove it,and set it up like I first thought...isolated from the pipe with clamps and an true air gap...
On your vacuum line,my buddy put a loop in mine,effectively shuting off heater control valve,but I have no heater...don't need it.
Rich
