once an operator is interested in a so-called issue aroused by a fellow homosapien, a motor neuron is triggered and causes an electric pulse to a array of nerves..... these then are used to force out an action that may or maynot take up a few minutes of the time.... time is relative to the passing of the moon, once the moon is in position, the bubbaness is out of the system....as retorting to a typed mistake and taking a back lash, those present tend to step back and see if his/her assumption was correct without thepost....... if the operator is correct, a sense of relaxation is present and the iq has risen .04 points..... thus, if wrong without the post, then a fire is created inside to offset the tension. most of the camber is on the shoulders when the head is to the side trying to understand what the post is about. if each atom is relative to the innertia then fourteen hotdogs will be served.... no soda or pop, just dogs.........
Simple... Everybody (let's say 100 people) looks once and may or not have an answer/opinion. Let's say 5 respond. That gives us 5 posts and 100 views. Of those 100, 50 are interested in following the topic regardless of their ability to comment. Every time somebody responds, 50 people look and may or may not respond to the newest post. After only 1 response after the first 5 (6 posts now), we have 100 views. at 7 posts, we have 150 views. With 8 posts, we see 200 views. Etc., Etc..
Now imagine the same scenario with 500 members online...or 1000...
