Calling all tall C3 drivers
Old Jul 14, 2005 | 08:33 AM
7Deuce's Avatar
7Deuce
Default Calling all tall C3 drivers
So my buddy and I drove each others cars for a few days and now I'm in love with C3's. I've pretty much decided to sell my C5 and start looking for a C3.
One thing concerns me when I begin looking for a car. I'm a taller person (6'3") and I find the C3 cockpit a little tight but manageable. The only C3 I've driven had a tilt/tele wheel. By extended the wheel and angling it up I was able to work the clutch without my knee hitting the steering wheel. In my early search I see that this option is not on all Corvettes. I worry that without the ability to move the wheel my knee will hit it each time I shift. This limits the cars I am thinking about looking at. So what do you tall driver's do out there to make some leg room? Anybody about my height have a fixed position steering wheel? Are my concerns unfounded? Are there ways to make more leg room like installing a little smaller diameter steering wheel or something like that? Appreciate any advice.
Old Jul 14, 2005 | 08:52 AM
Ganey's Avatar
Ganey
... smaller diameter steering wheel...? Appreciate any advice.
Yes, I put the Grant black leather one on my Corvette a long time ago. It has polished slotted spokes & a shallower dish which moves it closer to the dash. Nice, direct bolt on about 13 1/2". Model 791
Pic. on website.
PS Ideal height for C3 is Duntov's height to just over 6'.
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I put a modified racing seat in my '68 which lowersped the seat by about 2 inches...maybe more..
Old Jul 14, 2005 | 09:09 AM
68/70Vette's Avatar
68/70Vette
At 6"2" and about 210 pounds, I fit in my 68 Convertible with the stock wheel and non-T/T steering column. Getting in and out is a little awkward. My 70 Coupe, with it's air conditioning duct under the steering column can cause interference with my size 12 shoes. I usually take my left shoe off. Also, I reduced height of the seat back bumper. This allows me the seatback to lean back a little more and rest on the "firewall" behind the seats. Anyhow, once I get in the seat, I like the snug, low to the road feel you get in the C3.
There aren't many 68's with T/T steering columns. From 69 and on they become more common.
Old Jul 14, 2005 | 09:14 AM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Im not too tall, Im 5'11", we'll call it 6' for my ego. but I do not have tilt or telescoping I ride with the seat all the way back, but feel comfortable. try to get behind the wheel of as many as you can find to get a feel for what works.
Old Jul 14, 2005 | 09:17 AM
rihwoods's Avatar
rihwoods
Tip on getting in/out....lay your right ankle/leg to the side when getting out...gives more clearance under steering wheel....you can do same getting in..
Old Jul 14, 2005 | 09:30 AM
Paul @ Thunder's Avatar
Paul @ Thunder
I'm 6'1" and my '69 does not have tilt wheel either. I do have a smaller size Momo steering wheel which helps a lot plus being a Vert makes it a little easier as well.
Old Jul 14, 2005 | 09:50 AM
Ganey's Avatar
Ganey
Originally Posted by 68/70Vette
... My 70 Coupe, with it's air conditioning duct under the steering column can cause interference with my size 12 shoes. ...
That A/C duct goes to the side dash vent near the door & can be removed. Of course that makes a duct opening at the floor which can still allow the A/C to be fine. A smaller duct could be made.
I have removed that duct for awhile when making mods as it interferes w/ access to underdash wiring.
Old Jul 14, 2005 | 10:08 AM
Sleper's Avatar
Sleper
Put spacers in the front two mounting bolts. Make sure to use grade 8 bolts. I have a ¾ “ Spacer in the front of mine and it does help putting the rake and changing the seat angle. My $0.02
Old Jul 14, 2005 | 11:16 AM
rosslato's Avatar
rosslato
i'm 6'1 and had to slouch till i bought an astro top which gives you about 3" more of headroom and went w/smaller grant steering wheel. most people on the forum have bad things to say about astro tops but i've never had a problem w/mine in 13yrs i've had it nor has a buddy. sure they leak when i get caught in the rain but not anymore than my original tops. if u do go this route get the 1pc, the 2 pc are worthless
http://www.astrotops.com/68_82tops.html
Old Jul 14, 2005 | 11:32 AM
SpcCox's Avatar
SpcCox
I am 6 foot 2 and i have never had a problem getting in and out of my 76, i do have a T/T wheel and i like that i can sit all the way to the back as far as i can go and just bring the wheel to where its comfortable to me.
Old Jul 14, 2005 | 11:50 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
at 6-1 and 200 lbs, I put a Grant 13" wheel with 1" dish in my 72. Made a world of difference.
Old Jul 14, 2005 | 11:54 AM
NHvette's Avatar
NHvette
I'm average height, but I know a freind that bought another friend's 73 coupe.
The new owner is 6'6". He is now selling the vette due to knee problems and space. One thing he originally considered was to
remove and shorten the blinker stalk. This makes more room for the 'clutch' knee.
Another member here actually cut apart the floor area of the firewall and extended that a few inches for more legroom.
Old Jul 14, 2005 | 12:16 PM
Fevre's Avatar
Fevre
73 vert and the smaller wheel helped out a ton, made the manual steering a bit more challanging though.
82Vette'ster's Avatar
82Vette'ster
I'm 6'1" and my head would probably brush against the T-tops if they were the fiberglass ones. I've got the glass panel T-tops. They give that extra head room.
I thought that someone here had modified the firewall to make more foot room, I think that included modding the pedals. I was thinking of looking into that, I need about 1-2 inches. Maybe after I finish the stuff I've got started now.
Old Jul 14, 2005 | 01:09 PM
lg4vette's Avatar
lg4vette
Our 1980 is has an auto. trans and, like all '80's, tilt/tele. I'm 6'4" and don't have any troubles at all. I've driven a car similar to ours that was a stick and it was tough to work the clutch (size 14 shoes didn't fit too well).
If you absolutely require a manual trans., it sounds like a smaller steering wheel and/or seat modifications will help, however if an auto. is an option I think you'd fit in just about any C3 out there....
Old Jul 14, 2005 | 02:18 PM
James B's Avatar
James B
Im 6'3 250 with a 73 standard column and stock steering wheel. It is a bear to say the least. I took the door pull off of the door and that allowed me to be able to put my knee up one inch. I will get a smaller steering wheel here in the near future. I don't want to drop 600 bucks for a tilt steering column. If you find a car with a tilt steering column you will be set!
Like someone else mentioned, big feet are not good for 4 speed vettes. my size 14s sometimes hit the brake when im trying to push in the clutch, thats real embarassing
Also, your arm/shoulder is always against the door panel, but honestly, you get used to it and I love driving my car no matter how cramped it is.
To Calling all tall C3 drivers
Old Jul 14, 2005 | 02:26 PM
onaqwst's Avatar
onaqwst
yeah, i need a smaller steering wheel also......
b
Old Jul 14, 2005 | 02:41 PM
Tall Boy's Avatar
Tall Boy
I am 6'5" and have no problem driving my 80 auto, it feels better to me than most other cars
Old Jul 14, 2005 | 03:18 PM
7Deuce's Avatar
7Deuce
Thanks for all the replies so far guys. I experienced the "clutch knee" when I first started driving my friends '73. I forgot that the wheel telescoped as well as tilted. Every time I would shift my knee would press against either the door or the steering wheel. It made for awkward driving. Once I figured out the telescoping ability I had plenty of room. I just don't want to have to rule out the non tilt/tele cars. It would suck if I found the perfect car for me only to find out it doesn't have this option. Seems like such a small thing. Keep the replies coming. I like to hear how others make themselves fit into their cars. Gives me good ideas.
