How hot does your C3 run?
Old Jul 14, 2005 | 11:03 PM
JGreen's Avatar
JGreen
Default How hot does your C3 run?
Mine seems to be running hot after the frame off restoration is complete. I am not sure what it ran before because I never drove it. Today it was about 90 degrees outside, and my car was about 220-230 after a few miles of driving.
Old Jul 14, 2005 | 11:07 PM
Jclgodale3's Avatar
Jclgodale3
180-195 in 93 degree humid Alabama weather
Old Jul 14, 2005 | 11:27 PM
SkunkApe's Avatar
SkunkApe
Check your guage with an IR thermometer or a manual guage/sender. Mine was running "hot" (220) until I installed a manual guage. Now it runs at 165 ~ 185.
Old Jul 14, 2005 | 11:39 PM
Bangkok Dean's Avatar
Bangkok Dean
The temps here run mid to high 90 every day and my temps hold 180-185 even at the long stop lights.
Old Jul 15, 2005 | 12:32 AM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Have been averaging 220 - 230 with 383... am installing a 160 degree thermo to see if I can driveit down. Already has a Dewitt and dual SPALs.
Old Jul 15, 2005 | 01:15 AM
terry82's Avatar
terry82
190 normal 210 with the air on 90 degrees out .
Old Jul 15, 2005 | 01:22 AM
SkunkApe's Avatar
SkunkApe
T-stat regulates the low temp, no?
Old Jul 15, 2005 | 01:28 AM
Schmucker's Avatar
Schmucker
160 with 180 thermostat, stock L48. Apparently I have to coolest running C3 ever. I know the gauge is accurate because I have a 190 thermostatic switch on my electric fan and the one time it kicked on (idling for 20 minutes) the gauge read 190.
Old Jul 15, 2005 | 02:23 AM
James B's Avatar
James B
185...all the time. I could be sitting in traffic at 95 degrees in humid weather and it wouldnt over heat. I have a stock 73 L-48 that was converted to a 4 speed, so I have the big automadic radiator...plus I installed the biggest fan clutch ever
Old Jul 15, 2005 | 02:57 AM
Pauld's Avatar
Pauld
Around 190 all the time
Old Jul 15, 2005 | 03:30 AM
Buckman62's Avatar
Buckman62
Me too ! Spot on 190 regardless of outside conditions.
Old Jul 15, 2005 | 05:59 AM
Gordonm's Avatar
Gordonm
Gauge is reading about 180 most all the time. Checked the thermostat housing with an IR gun and I'm at 175 at the 180 gauge reading. Goes up slightly at idle but not much.
Old Jul 15, 2005 | 07:35 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
About 180-185 with dual spals & aluminum radiator. 180 thermostat.
Old Jul 15, 2005 | 07:37 AM
norvalwilhelm's Avatar
norvalwilhelm
Same here and that is with a blown bigblock.
Old Jul 15, 2005 | 08:21 AM
lvjohn's Avatar
lvjohn
I have a 71 Big Block runs about 190 in the summer,i live in las vegas
Old Jul 15, 2005 | 08:32 AM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
runs 195 until I get over 50 mph, then 220-240
Old Jul 15, 2005 | 09:19 AM
CGGorman's Avatar
CGGorman
To How hot does your C3 run?
Old Jul 15, 2005 | 09:34 AM
jaycjackson21's Avatar
jaycjackson21
200-210 all the time. Entire cooling system was replaced in 2004.
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I have an all stock setup with a 160 stat.. new rediator and it never gets over 160
Old Jul 15, 2005 | 09:41 AM
holley505's Avatar
holley505
IS it me are most of the late 70 cars running hot because of the gauges that are used?
It seems to me that these electrical gauges are off 10-15 degrees?
What is this about a replacement mechanical gauge? Does it look factory?
