Cowl-back body removal question
Old Jul 15, 2005 | 07:41 AM
lg4vette's Avatar
lg4vette
Default Cowl-back body removal question
Does anyone have a ballpark on what the body section weighs from the cowl back (doors attached, etc.)? Also, with the front end already removed, what is the -easiest- way to remove the rest of the body? I was thinking of eventually getting one of those lifts they advertise in the 'vette parts books, but it looks like it's designed to be used with the front clip attached?
Old Jul 15, 2005 | 10:04 AM
NHvette's Avatar
NHvette
The standard lifting harness should lift it OK with the front clip detatched.
However, it will definitely be 'tippy' toward the rear.
If you place another strap or rope to the rear to keep it
from tipping, I think you will be fine. The rear clip - totally
stripped of everything is a few hundred pounds. Doors, seats,
steering column, etc are all pretty heavy. Looks like your
seats are out in the avatar. Leaving the doors will help to keep
the front balanced in weight.
Old Jul 15, 2005 | 11:31 AM
427basketcase's Avatar
427basketcase
I removed mine without the front clip, using the "Sling" and an engine hoist. I was really pretty balanced, I didn't have any issues.
Just be slow and keep checking underneath for things to clear.
Old Jul 15, 2005 | 02:56 PM
lg4vette's Avatar
lg4vette
Does a standard engine hoist have enough lift to raise the body high enough?
Old Jul 15, 2005 | 03:18 PM
427basketcase
I had to tie a knot in each strap to gain the height, then tilted as needed to clear certain areas but overall worked real good.
Old Jul 15, 2005 | 04:43 PM
NHvette's Avatar
NHvette
Also depends on whether the engine and/or gas tank are still in the chassis.
To clear the engine, you'll need close to 3 feet of lift.
To Cowl-back body removal question
