homemade coil spring compressor
Old Jul 17, 2005 | 08:47 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Default homemade coil spring compressor
This is a $15 coil spring compressor that works:
It's a threaded rod with nuts and washers, the bracket is made from 1"X1/8" rectrangular mild steel - all available at Homedepot or Lowes.
I inserted the threaded rod through the hole that the shock mounts to (upper spring pocket), then aligned the spring in the upper pocket and inserted the bracket between the coils (2nd or 3rd from the bottom) and tightened the nut under the bracket hand-tight.... now I tightened the upper nut (above the upper pocket) with a ratchet and compressed the spring..... once the spring was 'short' enough I raised the lower A-arm..... done....
I highly recommend using Grade 8 material (except for the bracket of course) ... The cheap rod that I bought could actually break. I had a car jack (for a little safety) under the A-arm when I did this. It was a test to see if this "design" works. I'll build another compressor from better material, this galvanized China quality material is scary....
Old Jul 17, 2005 | 09:25 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Yeah, looks similar to the one Chuck Gongloff made in C2.
Old Jul 17, 2005 | 10:05 AM
007-8's Avatar
007-8
http://www.autozone.com/servlet/UiBr...compressor.jsp
Or free from Auto Zone, lone a tool. Just throwing out idea's.
Old Jul 17, 2005 | 10:32 AM
GTR1999's Avatar
GTR1999
I made one but it cost $30. I used acme threaded rod and nuts with a 5/8 steel plate. I put the plate under the lower control arm and jack up the whole mess one shot. The acme thread is better suited for this application, has almost a sq thread- just like the car jack.
Gary
Old Jul 17, 2005 | 10:56 AM
rcread's Avatar
rcread
The use of duct tape in this project is truly inspired. Duct tape just makes everything work better.
Old Jul 17, 2005 | 11:46 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
If the compressor looks like the one on the photo it may not fit as the claw seems to be too big.... but nice that AZ loans the tools with no charge...
Old Jul 17, 2005 | 11:48 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Bubbas tools: WD40 and DuctTape .... if it doesn't move but should use WD40, if it moves but shouldn't use duct tape.....
That tape is there to protect the powdercoating on the spring
Old Jul 17, 2005 | 01:38 PM
cptkirk32's Avatar
cptkirk32
I've always just used a jack, and let it down slow. Over here in OIF theater we sometimes have "bubbize" tools just to make things work. BFH, tape, bailing wire, oil, socket set, screwdrivers and a 5000lb tie down chain you can do allot of damage to M998A1, HET, 5-Ton, etc.
SGT Kirk
Old Jul 17, 2005 | 06:07 PM
big_G's Avatar
big_G
Sorry, but that looks DANGEROUS!!!. That threaded rod is probably the lowest grade steel. Please rent or borrow a real one..
Old Jul 17, 2005 | 11:15 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
It works fine, used it twice... however... read above in my first post "I highly recommend using Grade 8 material (except for the bracket of course) ... The cheap rod that I bought could actually break. I had a car jack (for a little safety) under the A-arm when I did this. It was a test to see if this "design" works. I'll build another compressor from better material, this galvanized China quality material is scary...."
You're right, what I used is the lowest grade steel you can find in this country....at Lowe's...
Old Jul 18, 2005 | 04:45 PM
Buzzardz_vette's Avatar
Buzzardz_vette
Advanced Auto is now loaning tools as well.
To homemade coil spring compressor
