Air Cleaner
Old Jul 18, 2005 | 07:50 AM
the_lane's Avatar
the_lane
Default Air Cleaner
Hi,
After some advise re: Air Cleaners.
My Car (1979, L48) has what I think is the stock setup - a closed aircleaner with a snorkle leading out to the front of the engine.
At most of the shows, I notice most cars have the open style air cleaners (i.e. raised chrome top with the air filter exposed).
So...
Is this a better setup to go with? - if the air filter is exposed over the engine, rather that a snorkle to the front, does that not mean it is taking in hot air? - i.e. would this give lower performance?
Is it better to go with a K&N filter or, stick with the stock paper elements?
Thanks!
(sorry if my terminology is wrong!)
Old Jul 18, 2005 | 08:08 AM
Pauld's Avatar
Pauld
Originally Posted by the_lane
Hi,
So...
Thanks!
You are right that cold air is much better, cold/dense air is what you really want. The snorkle setup gets more cold air than an open element.
I went with an open element when I rebuilt my 81 mainly because it looks better and neater
Old Jul 18, 2005 | 10:10 AM
Star79's Avatar
Star79
Urban legend (which may or may not be correct) says that for every 10*F drop in intake air temp you get a 1% increase in power. How much hotter the air hanging around in your engine compartment is depends on a lot of things though, so who knows what the real temp difference is at any particular time. Like Paul said the open ones look better, plus you may get more power back from them anyway in terms of better flow and unrestricted airstream.
Old Jul 18, 2005 | 10:26 AM
the_lane's Avatar
the_lane
Think I will go for it.
Any recommended brand?
Old Jul 18, 2005 | 10:28 AM
Techno's Avatar
Techno
The snorkels are very restrictive so any cold air they do get are canceled by this. If the snorkel is in the engine compartment then its hot air, has to be ducted in front of the radiator for cold.
14" dia. x3" high=132 sq in of open intake... the snorkel is around 9 sq in or so? for a 2.75" narrowest point diameter.
I have the windshield air scoop meant for the sealed air cleaner. But mine isn't, sits inside the scoop so kind of getting cool air and is 360* open element. Air is pressurized at the windshield so the rear facing scoop is actually under pressure. Have my cake and eat too.
K&N is a permanant filter and is supposed to flow better.
The chrome plated stamped steel K&N cover rusted, I replaced it with an edelbrock finned type and it didn't rust-aluminum? It also looks better specialy since my valve covers are finned.
The open element are "supposed" to provide like a 10% hp increase or something like that, I think that depends on a whole lotta things though.
Old Jul 18, 2005 | 10:39 AM
Pauld's Avatar
Pauld
On the 81's the cold air is taken from the radiator so this is alot colder than the engine bay. The dual snorkel design is a very good design. I only changed mine to an open element for the looks, looks less clutered.
Old Jul 18, 2005 | 12:01 PM
lg4vette's Avatar
lg4vette
So for those of you not using the snorkel setup, how did you determine what air cleaner would not present clearance issues with the hood profile?
I have the same question for intake/carb setups as well...
Old Jul 18, 2005 | 02:03 PM
Pauld's Avatar
Pauld
I am using a performer EPS intake, performer carb and a 3" tall drop base air filter
To Air Cleaner
