Straightening header flanges
Old Jul 19, 2005 | 11:56 PM
adam's Avatar
adam
Default Straightening header flanges
I'm cleaning and straightening out the header flanges...
Unfortunately, the flange is bent between the middle exhaust ports.
The center of the ports is lower than the two outer edges.
I've been able to flatten the flange by (lovingly)
at the right points to remove some of the bends.
But how can I straighten the low point in the middle?
Any low tech ideas?
Old Jul 20, 2005 | 12:09 AM
Techno's Avatar
Techno
Weld it and grind or file it.
Old Jul 20, 2005 | 02:28 AM
Frankenvette's Avatar
Frankenvette
On my passenger side header I made two cuts on the flange with a hacksaw to relieve the bow. I made a cut on each side of the middle two exhaust ports.
Old Jul 20, 2005 | 06:19 AM
fl_rider's Avatar
fl_rider
One of my friends says he has done that with every set of headers he has installed and never had a leak. He also uses copper gaskets.
I plan on doing this on my new set as well.
O cut OO cut O
Old Jul 20, 2005 | 08:23 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Use a file.
Start with a big bastard file and when it's flat switch to a finer file.
Old Jul 20, 2005 | 08:40 AM
Glenn"Mr.Blue"Smith's Avatar
Glenn"Mr.Blue"Smith
From: Edgewater (20 miles south of Daytona) Florida
He's right. Cut the flange. It wont effect the header from bolting up tight. In fact, those that have done so will all tell you it's better. Short of buying the new headers with really thick flanges, this is the best thing for keeping them sealed, along with the copper or good quailty gaskets. Hope this helps
Old Jul 20, 2005 | 06:19 PM
adam's Avatar
adam
Well, I was able to get the middle ports in line with the outer ports.
So I don't think cutting the flange will help much more with alignment.
Are there other reasons to cutting the flange?
I also used an abrasive pad to clean up the ports. I can try the file, but
the center is about 0.016 to 0.020" low.
Thanks.
To Straightening header flanges
