Help! Hood won't open on 72!
Old Jul 24, 2005 | 04:25 PM
CoolShark's Avatar
CoolShark
Default Help! Hood won't open on 72!
I have been putting my 72 back together and was adjusting the hood pins. I closed it and my left side won't pop open. I removed the side grill and can reach up to pull the release farther, but it still won't open. The oinf must be off center and not releasing. Any ideas?
Old Jul 24, 2005 | 04:37 PM
69 LT1's Avatar
69 LT1
Have some one pull the cable while you push down on the hood, If that does not work try this....
http://www.madvet.com/shop?frame=1.264.3852
Old Jul 24, 2005 | 04:58 PM
jdmick's Avatar
jdmick
It hasn't happened to me yet but after reading about it several times here I thought I'd take a look at what could be done. The article describes it pretty well. The toughest part would be how to fit the screwdriver and/or very small hand under the hood to push it through the hole and against the latch.
Old Jul 24, 2005 | 05:19 PM
CoolShark's Avatar
CoolShark
I have vise grips on the release cable, holding it in the release position, and have tried manipulating the hood. I can reach my hand through the side grill opening and push the release, but it doesn't work. I will try the screwdriver.
Old Jul 24, 2005 | 05:28 PM
Techno's Avatar
Techno
I think its the same. The drivers side activate a seperate cable/mechanism for the pass. side. Find this with your hand and activate this mechanism, or do the override plug.
At the very very worse you can undo the mounting nuts to the closed latch and start over.
Old Jul 24, 2005 | 05:41 PM
CoolShark's Avatar
CoolShark
How do you get to the mounting nuts?
Old Jul 24, 2005 | 06:05 PM
69 LT1's Avatar
69 LT1
Depending on what type of hood you have, If you can get a grab of it and pull to side,
I did that with my L88 hood once when it got stuck.
Old Jul 24, 2005 | 06:13 PM
Techno's Avatar
Techno
You reach up through the side gill and blindly place a wrench.
Last resort you don't want to do it. I had to once since the hood closed and was too far out to release.
If it won't open with the over ride plug. Try Try try to finding that finger on the cowl that releases the drivers side. It hits the hood mounted latch and cables over to the pass. side. You might be able to see it with it raised but don't force it open too far.
The hood shove works too if thats the direction needed to release.
Shove should be considered shove though.
Old Jul 24, 2005 | 07:48 PM
CoolShark's Avatar
CoolShark
The passenger side released. It is only the driver's side that won't. I will try all the helpful suggestions on Wed (my first ime I can get to my baby). Thanks, all.
Old Jul 24, 2005 | 08:08 PM
rihwoods's Avatar
rihwoods
Did you push your release handle in and try it again ? Might get lucky...
Old Jul 24, 2005 | 11:29 PM
CoolShark's Avatar
CoolShark
I'm not that lucky. I tried it upteen times, including while pushing and wiggling the hood. It's one stubborn @#$^&*
Old Nov 19, 2025 | 11:11 PM
Bob1947's Avatar
Bob1947
2nd Gear
I’m having the exact same problem? If anyone has a solution please share.
Old Nov 20, 2025 | 10:02 AM
Alan 71's Avatar
Alan 71
Hello Bob,
So....20 years have passed and hoods are still getting stuck closed.
Is it one side or both?
Can you sense if the hood release cable is moving one or both of the latches?
Regards......
Old Nov 20, 2025 | 02:17 PM
Bob1947's Avatar
Bob1947
2nd Gear
Default Hood won’t open
Alan 71.
If you pull the hood release the passenger side pops open, the driver side doesn’t. I took the grill off the fender and I can manually operate the driver side hood release but it still won’t release the hood.
Do you know of anyway to loosen the hood hinge bolts? I’m assuming the tang on the hood release is out of alignment a little bit.
Old Nov 20, 2025 | 03:11 PM
Piersonpie's Avatar
Piersonpie
The nuts are 1/2” if you can get a wrench or socket up there to loosen them. I’ve done that before and it works.
Old Nov 20, 2025 | 09:12 PM
20mercury's Avatar
20mercury
If all of the above fails after multible tries, I had the same problem on a 69 and just before I got out the sawzall to cut the hood off, I decided to try removing the parking light grills and reach up to the hood hinges and unscrew all of the hood hinge bolts. Unfastening the hood hinges allowed me to wiggle the hood around and it popped finally popped free. Last resort, but better than cutting the hood off LOL's!
Old Nov 21, 2025 | 12:11 AM
litevette's Avatar
litevette
It won’t help your situation, but might if it ever happens again… I plan to install these on mine. I’ve read too many stories like yours to not do so.
Old Nov 21, 2025 | 12:38 AM
Peterbuilt's Avatar
Peterbuilt
I don't have any suggestions to help you get the hood open but once it is open buy or build this tool to center the pins.
To Help! Hood won't open on 72!
