Trany Temp Guages
Old Jul 24, 2005 | 06:26 PM
Retro78's Avatar
Retro78
Default Trany Temp Guages
I have been looking around for a nice transmission temperature gauge. All the ones that I have seen have a capillary tube running from the trany to the gauge. Don't they make these things in an electronic version like water temp or oil pressure gauges. I would appreciate any recommendations and/or pics that you have of your setup.
Old Jul 24, 2005 | 06:32 PM
norvalwilhelm's Avatar
norvalwilhelm
Doug I ran one for years but it was the capillary tube type. I can weld a fitting in the side of the oil pan for you.
I found my 400 and 700 ran about 175 degrees and then I turned on the oil cooler fan. I had a seperate rad and 10 inch fan just for the transmission.
Removing the pan and welding a proper fitting in the side is not a problem.
How about Orangeville this Wednesday night???
Old Jul 24, 2005 | 06:59 PM
Jack71's Avatar
Jack71
You can buy a housing for the temp guage for about $10. Just drill a 1/2 inch hole and it bolt it on. Only bad thing is you have to drop the pan. Then you can use an electric sending unit type.
Old Jul 24, 2005 | 07:06 PM
1-MORTOY's Avatar
1-MORTOY
I have an Stewart-Warner trans temp gauge that I installed in my Suburban. It is electric, ie, sender in the pan with just a wire up to the gauge.
Gauge # is 82707 & sender # is 280EE. I did this about 13 yrs ago but maybe the parts are still available.
Old Jul 24, 2005 | 09:22 PM
Retro78's Avatar
Retro78
Hi Norval. Thanks for the offer to weld. If I need todo that I will certainly take you up on that. We PM you now about Wed and other updates.
Old Jul 24, 2005 | 09:36 PM
redwingvette's Avatar
redwingvette
The one I got from BTO when I bought the 200-4R trans is electric from B&M. The sensor is mounted into the dran plug with a treaded fitting.
Old Jul 24, 2005 | 11:56 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Autometer has a nice selection.
Here's how I mounted mine.
Old Jul 25, 2005 | 12:40 AM
rosslato's Avatar
rosslato
u did an excellent job on that alwayswave.
heres mine
To Trany Temp Guages
